Author Topic: The special tools Lending Library.  (Read 21697 times)
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: The special tools Lending Library.
« Reply #20 on: May 11, 2014, 15:15:56 »
I call shotgun if he does.
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #21 on: May 14, 2014, 17:36:01 »
Seal driver arrived today. Still waiting on the seals. I'll get it back to you ASAP. Thanks
Offline longman
« Reply #22 on: May 14, 2014, 18:15:56 »
I have to disappoint you blokes;) DRZ is not in the library;)
Longman
Suzuki DL650 K5
Suzuki DR-Z400SM K7
Offline mjc506
« Reply #23 on: May 15, 2014, 08:46:34 »
Quote from: "bigpie"
Good news :thumb: no rush, get sorted first :)
Quote from: "longman"
Terrible news :bawl:
Projects:
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #24 on: May 23, 2014, 13:15:51 »
Job done.
I'll give it a few days to check the new seals aren't leaking, then I'll sent the tool back.
Thanks for the loan.
Offline mjc506
« Reply #25 on: May 23, 2014, 15:27:21 »
Good stuff. Sounded like a typical 5min job (where everything that can, does go wrong!) Glad you got it sorted, make sure it's right before you post it back :)
Projects:
Offline Theflyingscot
  • Bike: DL1000 K7
« Reply #26 on: September 19, 2015, 08:10:50 »
Just wondering if anyone has a Carbtune I could borrow, local to the Derby are if possible.
Steve
Water is wet, Sky is blue. If you are after answers to any other questions Google it!!!!!
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #27 on: September 19, 2015, 08:15:08 »
I don't have a carbtune, but I do have a 2 dial vacuum gauge from I used to balance my TBs
  • Bike: DL1000 K7
« Reply #28 on: September 20, 2015, 09:19:00 »
Are they hard to use bigpie
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #29 on: September 20, 2015, 09:47:11 »
They might be, I've checked and I'm missing the hose extensions. The tails on them are about 5 cm. So they might not still reach both TBs.
Procedure is pretty simple iirc. Connect one gauge to on TB, then the other to same one, check they read the same, then plug on in to one and on in to other. Plenty of guides around on the web.
  • Bike: DL1000 K7
« Reply #30 on: September 20, 2015, 15:06:09 »
I've been looking on the web about the homemade manometers, thinking of trying one of those. Have you heard of anyone having any success with these?
Also do you know what dia the vacuum hose needs to be?
Offline TLPower
« Reply #31 on: September 20, 2015, 15:26:48 »
Bigpie I think we left the pipes connected to your previous 'bike.
Flyingscot, I have the same setup as bigpie. They use 5mm hoses but you need to use a reducer to control the dial "bounce". These are included in the kit.
You're more than welcome to borrow mine, or pop up and we can sort it one weekend. Check the TPS at the same time.
  • Bike: DL1000 K7
« Reply #32 on: September 20, 2015, 16:58:32 »
Cheers TLP, I'll give you a shout next time a have a weekend off.
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #33 on: September 20, 2015, 18:00:08 »
Doh, that sounds about right.
Offline sharealike
  • Site Donator
Anyone need loan of the clutch hub holding tool for taking out their clutch basket? I'm happy to put one or two in circulation. Can be passed on as and when required from owner to owner. No need for a deposit. Cost you the post to pass it on when the time comes.
Idea is the tool is posted on to you from the previous user. You need to use it twice. Once to take the basket out to send off for modification. Then a second time to fit the replacement/modified basket when it returns. Hold on to the tool for a while and post it on to the next person making a request here.
Please, please note. If your are taking a basket out to be rebuilt/modified or for something else I highly recommend use of this tool to save you damaging the actual clutch basket. Post cost to send it on would be up to £5 maximum. New baskets are over £200 and take near on a week to arrive. Ouch.
Download instructions how to use it here. http://www.vibefreev.com/downloads.htm
Offline Yoyo
« Reply #35 on: January 19, 2016, 23:39:07 »
That's a great offer, I also have one should anyone need it.
