Author Topic: Problem re-fitting handguard  (Read 1246 times)
« on: August 11, 2013, 19:12:42 »
My fault as I was not paying enough attention when I took it off.
Glee L3 left hand side knuckle guard
I find I have
4 washers
3 nuts (one dome headed)
two spacers
one bolt with a fixed hex
Try as I may I cannot put it all back together and be satisfied that it is all in the right place
I have looked at some line drawings but they do not show how the guard is mounted and I have more washers.
Has anyone got a decent drawing or photo of none correctly fitted?
Re: Problem re-fitting handguard
« Reply #1 on: August 11, 2013, 20:07:49 »
This shows the order.
« Reply #2 on: August 11, 2013, 20:59:15 »
Thanks greywolf very useful.
I think maybe an extra washer was put in by dealer who originally fitted it.
It still bothers me that the left side is so complicated and the right is so simple.
« Reply #3 on: August 11, 2013, 21:40:21 »
Quote from: "Brockett"
That's mostly due to a redesign of the clutch lever switch in 2010 because the old one caused too many problems. Changing some rather than all of the tooling saved money but increased complexity.
« Reply #4 on: August 11, 2013, 22:49:00 »
What changed, I can't see the difference to my K5?
ps. Which fiche site do you use? They seem to have complete instead of composite pictures.
« Reply #5 on: August 11, 2013, 23:21:51 »
I use the large image button for models at at http://www.mrcycles.com/
http://www.mrcycles.com/fiche_select2.a ... ggOIKw2N8F is the site for the 2012 DL650 for example.
Pre 2010 clutch switch
Much bigger 2010 and later clutch switch.
« Reply #6 on: August 11, 2013, 23:43:08 »
I thought you meant the handguard fixing bolt was different on the clutch side.
« Reply #7 on: August 11, 2013, 23:50:07 »
Quote from: "Juvecu"
It is. That is required to clear the bigger clutch switch.
« Reply #8 on: August 12, 2013, 09:23:25 »
Ah! that may be why the clutch lever does not appear to be central in the guard.
Maybe they reduced the clearance at the top to gain space at the bottom and clear the modified switch.
The top spacer is not shown in any drawings.
The top of the bolt is fitted with a dome headed nut that looks nice but seems to be only decorative.
I am concerned that the bolt's plain shoulder on which the clutch lever pivots does not extend fully into the pivot and this will cause wear in the lever.
I think maybe I'll look at this again.
All this due to fitting up and back risers and B'king handle bars. Standard Glee bars twist my wrists somewhat.
Hello ho!
Each time I write the word Glee
this, in brackets, appears.
« Reply #9 on: August 12, 2013, 13:03:17 »
It's Mr. Rat's latest attempt at getting better search engine ratings.
Offline Jacko
« Reply #10 on: August 12, 2013, 13:34:35 »
Glee Vee Wee
Offline Oop North John
« Reply #11 on: August 12, 2013, 14:14:19 »
Quote from: "Jacko"
Glee (V-Strom DL650 2012+) Vee (V-Strom DL1000 up to 2008) Wee (V-Strom DL650 from 2004 to 2011)
Gleeful gets through  :lala:
On my Suzuki handgaurds, which I've taken off and put back on a few times, I added a plastic spacer on the clutch side so that I wouldn't be able to overtighten the nut.
« Reply #12 on: August 12, 2013, 16:25:39 »
It makes my sig look like a mess. On the other hand, since an explanation is no longer needed, I can trim it.
