It should have a rubber on the top and the bottom? There is a spacer in the rubbers so that the bolt tightens on the spacer instead of pressing on the rubbers, the force you applied was probably just enough to overcome the rubber's friction and it twisted. I wouldn't worry about it at all, particularly since you had to use a breaker bar to twist it back, if it was loose you'd need a lot less force to twist it back.
