Vstrom DL1000 front ht lead
Topic: Vstrom DL1000 front ht lead (Read 908 times)
Mikemal87
July 25, 2013, 20:59:32 »
I need to replace my lead on the front but I need to find out if anyone know where to get one from as on ebay its all from the states and I need it as soon as really. or if anyone knows of other bikes the leads would fit off id be very thankful
Mike :p
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Re: Vstrom DL1000 front ht lead
July 25, 2013, 22:46:27 »
AFAIK the HT lead is not detachable from the coil pack. You'll have to replace the coil pack if there's a problem with the lead. All DL1000 and SV1000 use the same coil packs, but front and rear are different (just different HT lead lengths as far as I can tell.) Try searching for an SV1000 one if you can't find a DL1000 one.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
Juvecu
July 25, 2013, 22:48:47 »
There are some SV1000 coils on eBay.
Rear:
http://www.ebay.co.uk/itm/181028073093
Front:
http://www.ebay.co.uk/itm/181132917077
Members Map
Juv's Blog
Mikemal87
July 25, 2013, 23:21:45 »
wasn't sure about the sv 1000 I did hear they would fit and yea I know its the whole coil which is a little bit of a ball ache, thanks for the help don't seem be many around in the uk
Mike :p
greywolf
July 26, 2013, 00:23:02 »
Usually, all you need to do to get a better spark if there is a lead problem is unscrew the boot from the lead, cut off 1/4" from the wire end, and screw the boot back on.
