footpeg fumble
Topic: footpeg fumble (Read 759 times)
jabmotorsport
Four Time Quad Bike Champion
footpeg fumble
July 23, 2013, 18:27:47 »
Right then, had these on about a month or two now and mentioned I had problems fitting them but due to a mixture of work and lazyness I havnt explained why.
So then, these are the little buggers! .. link kindly from Locky
http://www.ebay.co.uk/itm/FOOTPEGS-Foot-Rests-For-Pit-Bikes-110cc-120cc-125cc-Strong-Grippy-Metal-Tops-/190866761482?nma=true&si=gwXuTsRYaFGMCqauF1OEy2z9vpQ%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
They are no longer available from this seller, but these are the ones I got.
Main problem I had is quite simply they wouldn't fit! haha the pin would not drop through the holes ... I started by widening the hole
sorry.
This didn't solve the problem, so fired up the angle grinder and gently took some of the straight bump stop away.
To do this job properly (I'm a fussy bugger), took me about an hour - hour and half, but no they fit perfectly
And for some pics!!!
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Re: footpeg fumble
July 23, 2013, 18:30:41 »
Your eBay link doesn't work. Did Locky have the same trouble as you did with the fitting?
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
Jacko
Bike: DL650 L2
Re: footpeg fumble
July 24, 2013, 07:36:22 »
That's a lot of messing about, are you sure you'd got them the right way round? ;)
jabmotorsport
Re: footpeg fumble
July 24, 2013, 09:26:17 »
Hahahaha I wonderd that!! .... Yes I did, they were 10 quid from China so maybe it was daft of me to believe they would fit first time
footpeg fumble
