Author Topic: L0?  (Read 764 times)
Offline neltek
  • Bike: V-Strom 650 GT 2010
L0?
« on: July 18, 2013, 16:34:14 »
I have a v-strom "60" reg
Is it an L0?
V-Strom 650 GT
ex:
SV650 K6
MZ301
Gilera DNA
Offline stibbs
Re: L0?
« Reply #1 on: July 18, 2013, 16:50:04 »
LO to you too....  :)
Offline willbo
  • crazy is contagious
  • Bike: 2010 dl650x
Re: L0?
« Reply #2 on: July 18, 2013, 16:52:03 »
60 is registeted 2010 but could be a 2009 model. In 2010 they changed the clutch lever switch  so different levers too. Have a look on your clutch lever for a large tab sticking out of the bottom of it. If it has that then u have a 2010 model
you can see the tab on the clutch lever on this picture here
Re: L0?
« Reply #3 on: July 18, 2013, 17:41:05 »
If the VIN model year system is the same world wide, and I think it is, you can tell by the 10th digit.
model year 2002 is a K2 with a 10th digit of 2
model year 2003 is a K3 with a 10th digit of 3
model year 2004 is a K4 with a 10th digit of 4
model year 2005 is a K5 with a 10th digit of 5
model year 2006 is a K6 with a 10th digit of 6
model year 2007 is a K7 with a 10th digit of 7
model year 2008 is a K8 with a 10th digit of 8
model year 2009 is a K9 with a 10th digit of 9
model year 2010 is an L0 with a 10th digit of A
model year 2011 is an L1 with a 10th digit of B
model year 2012 is an L2 with a 10th digit of C
model year 2013 is an L3 with a 10th digit of D
Offline Fatbelly
Re: L0?
« Reply #4 on: July 18, 2013, 20:48:16 »
It's on your registration document.
Re: L0?
« Reply #5 on: July 18, 2013, 20:55:16 »
That VIN number decoding doesn't seem to work in the UK. Mine doesn't have a 4 in the 10th digit (or any digit as it happens).
I do have an "e4" in some other coding and the "e4" is also on the VIN sticker. Maybe someone with a bike from any other year could check to see if there is an "eX" number on theirs, where the X refers to the year?
Offline willbo
  • Bike: 2010 dl650x
Re: L0?
« Reply #6 on: July 18, 2013, 21:17:09 »
I have a 2010 abs wee. It also says e4. But honestly, check the lever type. 10 seconds and u can see if its an 09 marked as 2010 or an actual 2010
Offline neltek
Re: L0?
« Reply #7 on: July 18, 2013, 21:54:52 »
cheers all - Will have a look :)
Just charging battery at the moment - see my other post for today ! :)
V-Strom 650 GT
ex:
SV650 K6
MZ301
Gilera DNA
Re: L0?
« Reply #8 on: July 18, 2013, 22:47:40 »
Without the 10 VIN digit working, the clutch switch is the best way to tell a K9 from an L0. Oh, and looking at the documentation.
