Author Topic: Tyre psi  (Read 697 times)
Offline james.t
  • Bike: DL250
Tyre psi
« on: July 15, 2013, 22:09:49 »
I have got myself a new Anakee2 rear tyre (big screw though the one that had only done 5000 miles)
so I run it at 35psi but on a hot day it feels loose, have now put it up to 40 psi, just wonder what is meant to be the right pressure for the back (manual says 35 solo and 42 pillion) but I ride solo but have got a heavish topbox.
j
Re: Tyre psi
« Reply #1 on: July 15, 2013, 23:00:47 »
I'm ~12 stone and I have it on 37psi without any issues. It might not be the tyre, it might be your rear suspension (mine's got an uprated spring and I'm not even heavy.)
Offline willbo
  • crazy is contagious
  • Bike: 2010 dl650x
Re: Tyre psi
« Reply #2 on: July 15, 2013, 23:11:17 »
I've not upgraded my rear spring.  I'm 16 stone but add top box and gear onto that. I've got mine set to 37 psi too and seems OK
Offline user650
Re: Tyre psi
« Reply #3 on: July 16, 2013, 00:11:36 »
+1
16 ish Stone standard suspension and running 38 psi
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Offline james.t
  • Bike: DL250
Re: Tyre psi
« Reply #4 on: July 16, 2013, 20:23:03 »
OK thanks all
