Author Topic: Identifying *Spare* Plugs  (Read 1469 times)
Offline Descolada
« on: July 13, 2013, 17:54:02 »
Hi All,
So I am continuing my mammoth maintenance and additions project. Just completed the maintenance tasks and am about to move to additions  :)
I was also continuing general cleaning as I go along and found myself sitting looking at the nearside of the bike. I had been in the process of cleaning off some rather unsightly grime and crud from the electrical harness and associated plugs when I realised that I seemed to have some *spare*. As well as general interest I wondered if I could make use of these for any electrical source connections.
Here are the three plugs in question;
Des
Offline Jeff999
Re: Identifying *Spare* Plugs
« Reply #1 on: July 13, 2013, 19:46:58 »
I think you'll find they are some kind of bridging connectors. Try using the search box on the top right. It will lead you to most of the topics you need.  :)
« Reply #2 on: July 13, 2013, 19:51:35 »
Plug 1 is the plug you would use for dealer mode or connecting a Yoshi box or such, it's the ECU connection plug.
Plug 2 is a jointing 'block' for several earth wires and not really a plug.
Plug 3 I'm not 100% sure, but I think it is used for the Suzuki/Acumen alarm connection. Greywolf can probably confirm/correct me on that.
« Reply #3 on: July 13, 2013, 20:14:53 »
The one with all black wires is a diagnostic plug. USA bikes don't have it. The dealer mode connector has six openings for four wires including a white/red and a black/white next to each other. The third is also a connector I've not seen, not only on USA bikes, but in the wiring diagram for Euro bikes. A connection for an accessory like an alarm would make sense.
« Reply #4 on: July 13, 2013, 23:47:32 »
Wires shouldn't get hot... :neen:
« Reply #5 on: July 14, 2013, 00:31:51 »
This may be the only wiring thread I've ever done where I did not talk about a hot wire. I know "earth" is used in the UK for the negative wire I would normally call a ground wire. Do I need to use a different description here from "hot" to describe the positive wire?
« Reply #6 on: July 14, 2013, 01:05:16 »
I'm messing with you, mate :) You frequently use hot though. I notice it every time because I used to work for American Power Conversion (APC) and because the UPS units were all designed in Rhodes Island they use the term "hot" instead of Live/Positive. I have no idea if most others on here are familiar with the term or not.
Offline ziggy
« Reply #7 on: July 14, 2013, 06:06:42 »
Quote from: "greywolf"
On some model Suzuki's the plug with the 4 black wires is used for connecting an alarm. If the socket has a plug in it you will see that the plug shorts out two of the black wires. Don't know if this applies to the DL.
« Reply #8 on: July 14, 2013, 08:20:33 »
Let's change the filter to switch from "hot" to "live".
Then we can come up with such gems as "hot a-s-s" turning into "live donkey".
 :text-threadjacked:
« Reply #9 on: July 14, 2013, 10:04:13 »
I am just here for your amusement   :GRR:
Offline iansoady
« Reply #10 on: July 14, 2013, 10:39:27 »
According to the wiring diagram, plug 3 is connected direct to the ECU. I think it may be used for remapping using something like a Yoshi box but would welcome more info.
For reasons that escape me some previous owner has chopped off plug 1 leaving the wires waving in midair - I intend to fit a switch so that dealer mode is instantly accessible.
Ian.
2005 DL650
1931 Sunbeam Model 10
« Reply #11 on: July 14, 2013, 11:22:26 »
Ian, there's a live on that so best make sure they are insulated.
Offline iansoady
« Reply #12 on: July 14, 2013, 15:54:38 »
Yes indeed - they're actually quite short so I don't think there's too much risk but it is around number 7 on my list of 50 or so.... :shock:
Ian.
2005 DL650
