Author Topic: Remove Chain Guard  (Read 1301 times)
Offline heatha
Remove Chain Guard
« on: July 10, 2013, 23:21:27 »
Chaps,
How on earth did you remove the chain guard on the Vee. I cannot get that second screw out cause of the pipe being in the way!
Is there a specific tool or method you used?
Thanks!
Offline heatha
Re: Remove Chain Guard
« Reply #1 on: July 11, 2013, 14:51:58 »
Someone must have had this issue and resolved it, surely?
Offline Abercol
  • Bike: 2016 Explorer XRT
« Reply #2 on: July 11, 2013, 14:53:51 »
Nope...never taken my chainguard off....however, have removed the rear pipe to change the dog bones, only two bolts and a minutes work.....
Offline heatha
« Reply #3 on: July 11, 2013, 15:54:44 »
Hmmm OK. I looked at the pipe and thought it had the general appearance of being welded. I'll look again thanks
Offline Big Al wi the Vee
« Reply #4 on: July 11, 2013, 16:48:37 »
Heatha,
I have removed the chain guard to fit my Hugger,but I don't remember having much trouble!
Just try and find a suitable alternative to a screw driver and if it has a nut inside the guard try turning the nut from the inside while holding the screw steady  :shy:
a picture would be nice... of the screw that is :shy:  lol  :grin:
good luck
Offline Buggrit
  • Bike: DL650 AL2 white Glee
« Reply #5 on: July 12, 2013, 00:44:34 »
Don't know if they're the same, but on the glee the front fixing is a phillips 3 screw which is obscured by the rear pillion footpeg. There is a screwdriver-sized hole in the footpeg plate which allows access using a long bladed screwdriver. I bought 150mm length one for £2.50 from my local Screw-Fix store which did the job nicely.
Here's the item link:
http://www.screwfix.com/p/forge-steel-s ... 50mm/67466
Live fats die yo gnu....
Offline heatha
« Reply #6 on: July 12, 2013, 10:16:57 »
Thank you for all your help. I just guess I need to find the correct right angles screwdriver, I'll start visiting the hardware stores.
Things would be so much easier on here if I could post photos :old: !
« Reply #7 on: July 12, 2013, 11:19:21 »
Quote from: "heatha"
Why can't you?
Offline Jacko
« Reply #8 on: July 12, 2013, 12:07:38 »
Quote from: "Buggrit"
Can't you just remove the footpeg?
Offline heatha
« Reply #9 on: July 13, 2013, 07:17:10 »
No not on the Vee, the second pipe is in the way. Can't use a normal screwdriver, need a right angled type piece.
As for photos, I just don't know how to post them I'm afraid. I thought I needed a special access?
Offline kissofdeath
  • Bike: Veek
« Reply #10 on: July 13, 2013, 08:02:02 »
here are 2 ways of adding photos viewforum.php?f=46 or you could start a photobucket account (its free) then paste the link  :)  :text-worthless:
Offline heatha
« Reply #11 on: July 15, 2013, 14:23:52 »
I removed the left exhaust to get the chain guard off, put the hugger on and everything back together, now the bike won't start, it tries ti fire up but can't. Oh dear!  :groan:
« Reply #12 on: July 15, 2013, 14:42:37 »
Whenever the engine cranks but doesn't start, the first thing to try is opening the throttle while cranking. The usual problem is flooding and opening the throttle lets in more air.
Offline heatha
« Reply #13 on: July 15, 2013, 14:58:09 »
Massively grateful and feel somewhat ashamed. It's fine! Thank you.
Offline Jacko
« Reply #14 on: July 15, 2013, 15:01:53 »
Ashamed? Of what?
Offline heatha
« Reply #15 on: July 15, 2013, 18:10:56 »
Not thinking of opening the throttle :-)  :text-givemebeer:
« Reply #16 on: July 15, 2013, 18:52:30 »
Believe me, you are not alone. Modern fuel injection systems are normally very good when starting as long as no throttle input is used so the idea of using throttle has been taboo. It is still useful when an engine doesn't start right away though.
