So this all started on Sunday with a centre stand clean up. As mentioned this was done with some Hammerite Satin Black I had left from a previous job. The stand was taken off the bike, involved in a skirmish with a wire wheel and a power drill for about 45 minutes and then hard to reach places had some sand paper pulled over them. I washed it with ordinary washing up liquid and water and left it on the black bin to dry out in the sun. It was bone dry in about 10 minutes, the weather is lovely. I had bought some Kurust earlier the day and I set about painting it well. It's milky white stuff and it converts rust to a stable surface. I think it works by creating a different iron oxide that's black and has a smaller stable molecule (instead of red/brown rust which has a very large molecule.) It's good stuff and you can paint over it once it's dry. I left it overnight to dry.
On Monday I set up an area in the backyard in a wind quiet corner for spray painting small stuff. I just stapled some thick plastic to the wall and used a few sticks to keep it down. I applied lots of thin, quick coats and made sure to get it into every nook and cranny I could. In total I did about 7 or 8 coats and left if for 15 mins in between each to dry a bit, but not enough so that it wasn't tacky any more. After all the coats were on I left it in the sun to get some heat into it.
My makeshift "spray booth":
After a few coats of paint:
The end result:
Unfortunately I didn't take a 'before' picture, but I can assure you it was looking very sad. It's a bit too fancy looking now to put back on the bike because it's the only thing that's in good nick
