Front I believe is on number 2 from the factory and 2 rings showing on the rear.
rear damping adjuster is all the way in and back out 1 and a half turns.#
I have the front set to position 1, rear at 2 rings showing, and the damping a little stiffer than normal.
when the mrs on the back the rear preload goes up to the max.
