Author Topic: Help! I need someone with (access to) a lathe!  (Read 2531 times)
Offline iansoady
Re: Help! I need someone with (access to) a lathe!
« Reply #20 on: July 04, 2013, 13:26:34 »
Huh, spurned.......
Ian.
2005 DL650
1931 Sunbeam Model 10
Offline mjc506
« Reply #21 on: July 04, 2013, 13:59:36 »
Sorry, nothing personal :shy:
Projects:
Offline iansoady
« Reply #22 on: July 04, 2013, 14:52:21 »
I know, but when you've been rejected as often as I have.... :old:
Ian.
2005 DL650
« Reply #23 on: July 04, 2013, 15:16:20 »
At least you still have the Matchless :)
Offline mjc506
« Reply #24 on: July 04, 2013, 16:19:56 »
awwwww *e-hug*
Projects:
Offline mjc506
« Reply #25 on: July 12, 2013, 18:45:39 »
I have the tool :) (but lost my camera?!)
Very good quality machining - if anyone needs a machine shop and is localish, Jarvis Engineering in Wycombe comes highly recommended! Proper lathes, proper mills, proper technicians :) (and some fancy new cad-cam kit too)
Projects:
Offline mjc506
« Reply #26 on: July 25, 2013, 11:48:28 »
Finally some progress!
I used my new tool to press the old journal bearings out. I was expecting this to be a complete arse, but it wasn't too bad!
Next, fit the new journal bearings into the other part of the tool, and tighten up the screw a touch (not as tight as possible, just 'wrist tight')
Heat up the casting (every little helps) and smother the surfaces with engine oil
I didn't take photos here, as I was terrified of it all going wrong! Place the ring containing the new bearings over the hole, aligning the split between the bearings with the marking on the casting. Now use the other part of the tool to press the bearings from the ring into the casting - this keeps everything straight and aligned.
Done!
Projects:
Offline iansoady
« Reply #27 on: July 25, 2013, 15:36:29 »
Nice to see what the tools were used for!
In fact, for that clamp it didn't really need the screw - a simple ring with a slot cut with a hacksaw then a Jubilee clip round the whole job would have done. It's essentially similar to a piston ring clamp.
Great stuff and keep up the good work.
Ian.
2005 DL650
Offline mjc506
« Reply #28 on: July 25, 2013, 15:54:01 »
...a jubilee clip probably would have worked actually... never mind :)
Projects:
