Hot seat when left in sun
Topic: Hot seat when left in sun (Read 1088 times)
frez
June 19, 2013, 08:52:02 »
Anyone got a favourite solution?
Where I am working now the bike is parked out in the sun all day. Any sunny day (few at the moment) and I'm getting roasted nuts on the way home.
I'm trying paper towels over the seat today.
mjc506
Re: Hot seat when left in sun
June 19, 2013, 08:55:38 »
a sheepskin actually works wonders
But yeah, anything covering the seat will do the job, so long as it's not black. The reflective car windscreen cover thingys should work nicely
Projects:
DL650 engine rebuild:
Complete!
Brighter rear indicators]
Complete!
[/url]
Heated mirrors]
Complete!
[/url]
Abercol
Bike: 2016 Explorer XRT
June 19, 2013, 08:57:32 »
You need.....
http://www.cycleshade.com
Jacko
Bike: DL650 L2
June 19, 2013, 09:03:57 »
Pour water on it before you start kitting up, should cooI it enough to sit on.
frez
June 19, 2013, 09:35:22 »
Trouble is it is a gel seat and the gel retains the heat, stays hot for over an hour. Would be great in winter.
Fatbelly
Reply #5 on:
June 19, 2013, 10:01:41 »
When in hot countries I tend to chuck a towel or t-shirt over it.
DesertStrom
Bike: DL650 K9, Triumph Street Scrambler
Reply #6 on:
June 19, 2013, 11:42:24 »
An old towel, white to reflect the heat is better & pour water over it. The water evaporation will chill the seat/gel down. Does have to be kept wet though! If you can return to the bike every few hours or so it will work OK.
adst
Reply #7 on:
June 19, 2013, 15:21:41 »
I use a motrax seat+ clocks cover up
Ebay 290537945033
Doubles up to keep dry in showers and cooler by reflection and pigeon stuff and packs really small - under seat or in box.
Because life is the journey not the destination?
"Dr.Pat Garrod ..Bearback "
