Author Topic: Stuck in gear?  (Read 54013 times)
Offline Jacko
Re: Stuck in gear?
« Reply #180 on: August 12, 2013, 17:04:59 »
Makes sense, halves the life of the plugs though. :D
Re: Stuck in gear?
« Reply #181 on: August 12, 2013, 17:20:12 »
Maybe that's why the plug replacement schedule is so ridiculously short. Anyway, the effect on the plug of igniting the mixture is much greater than throwing a spark in an exhaust stroke. I wouldn't put the additional wear at anything approaching half.
Offline mjc506
Re: Stuck in gear?
« Reply #182 on: August 12, 2013, 20:52:30 »
Yeah, wasted spark is pretty common. I'd more interested in the injection side of things :)
Today, I passed an MoT :)
...and emptied a fuel tank through the main rear drain port :)
I don't know if it's faded memory, but the Wee feels smooth, predictable, and more powerful than before? It's loosened up nicely, sounds fantastic, and I've still got a silly grin on my face :grin:
By the end of the week I should be back onto synthetic oil, and running in will be pretty much complete :lala:
Projects:
Re: Stuck in gear?
« Reply #183 on: August 12, 2013, 21:13:14 »
I cannot really say this thread is worthless without pics, so where's the promised video of it running?
Oh, and very well done.
Offline iansoady
Re: Stuck in gear?
« Reply #184 on: August 13, 2013, 12:23:15 »
That (wasted spark) would be OK on a 360 degree twin (or 2 sets of wasted sparks on a four) but I'd be a bit suspicious on a 90 degree V twin.
Ian.
2005 DL650
1931 Sunbeam Model 10
Re: Stuck in gear?
« Reply #185 on: August 13, 2013, 13:01:52 »
The way I understand it: for fuel injection it's more a case of how long the injectors stay open rather then when exactly they open. As long as there is enough fuel to suck in when the intake valves open it's all fine :) At idle the injectors only open for milliseconds, at full revs they can be open 80%+ of the time. Engines with both crank and cam sensors can be more accurate with the "when", if needed.
Offline Jacko
Re: Stuck in gear?
« Reply #186 on: August 13, 2013, 13:25:07 »
Quote from: "iansoady"
Crank and TDC relation remains constant regardless of configuration.
Re: Stuck in gear?
« Reply #187 on: August 13, 2013, 13:37:32 »
Quote from: "Juvecu"
Right. The fuel pressure to the injectors is constant. At 43psi, a bypass valve in the pump starts to open and delivers excess fuel back into the tank. Since the pressure is constant, the amount of fuel fed to the combustion chambers is determined by how long the ECM holds the injectors open. The ECM takes information from the sensors to determine how long to hold the injectors open.
Offline mjc506
Re: Stuck in gear?
« Reply #188 on: August 13, 2013, 14:27:24 »
Good point. I'm a retard :) I rebuilt the thing and I was still imagining injectors in the combustion chamber :doh: I guess there's a pretty big volume of air between the injectors and valve seats to hold fuel vapour/air in, especially at those sorts of speeds/frequencies.
I need help again.... where do I stick this fantastic gel domed sticker that Mr Rat sent me? My first though was on the top of the tank, but I'm kind of holding out for a v-strom.co.uk tank protector :shy:
Video as requested :)
Projects:
Offline Keith Cross
Re: Stuck in gear?
« Reply #189 on: August 13, 2013, 14:29:06 »
Vstrom definitely not a wasted spark system.  Maybe someone has got confused as each coil runs 2 spark plugs in the same cylinder with later models.
Keith C
2006 Vstrom DL1000GT
1990 Honda GL1500
1981 Goldwing Interstate
1966 Triumph 3TA
Offline mjc506
Re: Stuck in gear?
« Reply #190 on: August 13, 2013, 14:35:27 »
Certainly not in the traditional sense (all cylinders spark at the same time) but perhaps in the sense that each cylinder sparks on every crank revolution.
don't know, just educated guesses really.
Projects:
Re: Stuck in gear?
« Reply #191 on: August 13, 2013, 14:39:51 »
Video =  :)
Re: Stuck in gear?
« Reply #192 on: August 13, 2013, 14:46:18 »
Another possibility is the ECM uses a camshaft position sensor to distinguish the compression stroke from the exhaust stroke. I haven't seen anything in the manual that addresses the specifics on the matter.
Edit: As they say in New York, fagedaboutit. Only the Vee has a camshaft position sensor.
Offline mjc506
Re: Stuck in gear?
« Reply #193 on: August 13, 2013, 14:55:21 »
Quote from: "MartinW"
Video =  :)
:grin:
GW, there's a camshaft position sensor on the Wee?
I guess it doesn't matter anyway - the lump runs :)
Tonight's job is another oil change, and I'll go over all the fasteners to find any that I forgot to tighten...
Projects:
Offline Descolada
Re: Stuck in gear?
« Reply #194 on: August 13, 2013, 15:30:34 »
That was so funny (video) I wasn't expecting the audio overlay ... GULP! ... or is that how it really sounds  :shock:
Re: Stuck in gear?
« Reply #195 on: August 13, 2013, 15:36:15 »
Quote from: "mjc506"
It was listed in the index. A further check finds no other reference. It's only in the Vee and Suzuki must have used the Vee manual as a boilerplate.  :angry-tappingfoot:
I'll go back and edit previous stuff.
Offline mjc506
Re: Stuck in gear?
« Reply #196 on: August 13, 2013, 15:51:16 »
No problem! I just panicked and thought I'd forgotten to install a component! :)
Here's the real video :)
Projects:
Re: Stuck in gear?
« Reply #197 on: August 13, 2013, 19:07:33 »
:thumb: at the first video, it was a real  :wtf:  moment for me!
Offline mjc506
Re: Stuck in gear?
« Reply #198 on: August 13, 2013, 20:13:39 »
:grin: I actually hadn't listened to it before I posted. Better than anticipated :)
Projects:
Offline mjc506
Re: Stuck in gear?
« Reply #199 on: August 16, 2013, 13:33:37 »
Updates:
Run through a few tanks. Fuel consumption seems back to normal/better. I'm convinced the engine is running better than I've experienced before. Even my pillion commented how smooth it was. I'm guessing a bit of love to the clutch, coupled with de-coking everything has helped a lot. I haven't managed as many miles as I expected (cursed weather), so I'm still on dino goop. I'll go synthetic @~1000miles. The oil changes have been easy. Very little crap in the oil coming out, although the first filter had a reasonable amount of aluminium in it. Nothing since. The last oil change was possibly a waste of time, as it came out the same colour it went in :)
No leaks/vibrations/bits falling off either :haha:
Problems:
Something isn't quite right with the electrics. Yesterday evening, after a bit of rain during the afternoon, I switch the bike on, thumb the starter and nothing happens. Switch off and switch back on again, and it starts fine. :shrug: This morning, after a night of rain, switch on, fuel pump and STVA make the right noises, but no starty :( I get the solenoid click, but no movement. C12 on the dash - Crankshaft position sensor. I imagine I would have had the same come up last night, but it took a good few seconds for it to appear.
I can't get to the CKPs plugs at the moment, so couldn't check that, but the service manual seems to indicate that the engine should still crank with that sensor failed (FI Troubleshooting, C12 CKPS) This wasn't cranking even. The solenoid was clicking when pressing the starter button, but the starter wasn't running. (Sound familiar?) I'm wondering if the C12 is correct?
The solenoid clicked was fresh in my mind from the weekend, so I tried the spanner trick (shorting the solenoid terminals). Nothing. A tiny spark (really small?!) but not movement. In desparation, I left the ignition on, and jumped between the battery +ve, and the starter motor. Engine bursts into life! At this point, I'm late for work so I get on (not forgetting to pocket the handy length of wire, just in case...) and ride off. Bike runs perfect all the way to work. No other troubleshooting done yet. No FI indications, just C00 all the way.
So if it's running, then the CKPS must be OK, right? This solenoid deserves some investigation. I'll try jumping from battery +ve to the solenoid 'output' too to check the wiring between solenoid and starter motor.
Any other ideas? :shrug:
EDIT: just been out to have a play. It's all working fine now - it's dried up a bit, so I'm thinking connections somewhere. Unfortunately, I left my multimeter turned on, so it's now dead  :bawl:
Projects:
