So... after a great week oop norf, the bike behaved perfectly until ~100miles from home on the way back.
M1 southbound, and I flash a truck across into my lane to let someone join off the sliproad. I shift into 4th to accelerate away again, and then discover I can't shift into 5th! Can't get into 3rd either, so I stop at the next services to see if I can free it up. (sidenote: manoeuvring an overloaded strom through a carpark is difficult in 4th)
The lever moves a little up and down, but stops dead just before it should click up and down the gearbox. The clutch is fine, actuates nicely, and locks/opens fine (and feels 'right'). Rotating the back wheel back and forth while trying to shift makes no difference, and I can't feel anything moving internally while I do.
So I give up, and decide to get back home in 4th. I make it out of the services and onto the motorway fine, but as I take my exit, I have to get round a roundabout, then go up a steep hill. Riding the clutch this hard to get going overheats it, and I now have no real power. The RAC rescue me this time
So I've cooked the clutch, and something's up with the gearbox. I've not found any reports of gearbox problems for the DL650 or the sv650 that match my symptoms (although there's an sv report that's close) but I'm hoping I can see/fix the problem just by taking the clutch and gen covers off!
Current plan is to open it up, check/service/fix the clutch, and see what I can see around the gearbox before I do any more. Where's best to get a 'pack' to service the clutch? And I can't find which gaskets I need, but found mention of people using a liquid gasket... is this as good?
Ta
