Author Topic: bar end weights install problem  (Read 2259 times)
Re: bar end weights install problem
« Reply #20 on: May 30, 2013, 23:06:37 »
I saw how they went together before I removed them... because the road did a good job of removing them for me to take a look at them  :shy:
« Reply #21 on: May 30, 2013, 23:35:24 »
Quote from: "mr_diver"
.... because the road did a good job of removing them for me to take a look at them .....
Same here, one of my first set fell out on a ride somewhere, so I found out how they work when the new ones got delivered.
Offline EireSkull
« Reply #22 on: February 02, 2014, 17:20:48 »
Oh no was just fixing the heated grips and just unscrewed the bar end out and can't get it back in :eusa-doh:
« Reply #23 on: February 02, 2014, 18:06:11 »
You have to use a wire to fish the expander plug and its central nut out or take the other end off properly and use a flexible rod or compressed air to push it out.
Offline Abercol
  • Bike: 2016 Explorer XRT
« Reply #24 on: February 03, 2014, 12:20:42 »
Or take off the other side and stick the garden hose on the bar...flushed out the nut a treat....Just had to find it on my driveway afterwards.
I didn't have any flexible wire or piping to hand and the only compressed air I had was in the tyres!
Had to leave the ends off while it dried out though.
Offline EireSkull
« Reply #25 on: February 03, 2014, 18:24:02 »
I'm going to give both of those ideas a go just waiting on the rain to stop, can I ask this on Greywolfs diagram Bolt #5 do I try to take that out first as its really jammed in, or does it all come out together.
« Reply #26 on: February 03, 2014, 19:08:09 »
#5 is an all metal part and shouldn't be hung up. The #8 rubber part and #9 nut inside are usually the only parts that stick inside the bar. If #5 is stuck, tapping it should free it up.
Offline DEF2001
  • Bike: 2015 V-strom 1000
« Reply #27 on: September 22, 2014, 21:12:55 »
Can this post get displayed at the top of the page because I have just gone and done the same thing then had use an wire coat hanger as described to tease out the rubber bar ends. If only I knew then what I know now I could have saved myself 1/2 an hour. :angry-tappingfoot:
« Reply #28 on: September 22, 2014, 21:21:25 »
If someone writes up a sensible post, with pictures, then I will put it in the TOP TECHNICAL POSTS section.
Offline Jacko
« Reply #29 on: September 22, 2014, 22:33:47 »
Another one... Will they ever end?
Offline EireSkull
« Reply #30 on: September 23, 2014, 10:07:41 »
Got mine out in the end inside of the bars were full of rust,never seen anything like it had to take the handle bars off the bike.
