Author Topic: Engine bar mounted running lights  (Read 1066 times)
« on: May 03, 2013, 23:13:05 »
Recommendations for my Glee please?
Re: Engine bar mounted running lights
« Reply #1 on: May 04, 2013, 00:45:45 »
I recommend that you not fall over after mounting them, they will be in between the ground and the bars/something else :)
« Reply #2 on: May 04, 2013, 09:13:09 »
Quote from: "Juvecu"
Good advice  :angry-tappingfoot:
 :neen:
Offline putbinoot
« Reply #3 on: May 04, 2013, 10:36:25 »
Or mount them on the rad shield like me. Don't look at the rust.
Offline Locky
« Reply #4 on: May 04, 2013, 10:45:35 »
I got a few blokes from ST6 to send me the info for the lights they had fitted . I'm ordering these when I've decided on what engine bars I'm getting
http://www.aliexpress.com/item/10W-Work ... 52113.html
« Reply #5 on: May 04, 2013, 12:04:04 »
Most seem to mount them on the outside of the bars or on top of the bars where they will get hit in a fall. I like your mounting location better, putbinoot :thumb:
« Reply #6 on: May 04, 2013, 12:06:14 »
Locky, will you have to buy a separate bar clamp/mount for those?
Offline Mitch
« Reply #7 on: May 04, 2013, 12:27:50 »
Engine bar clamps are expensive. I used armoured cable cleats, different sizes available depending on the girth of your bars. These mounted ontop of a bed of wrap or two of insulation tape save you tons of cash. They cost pennies. Have a look at mine at Squires if you're going. If you know width of your engine bars before the meet let me know ill fetch some along (I sell electrical gear for a living ,so can get them cheap).
VSTROM - ADVENTURE IS OUT THERE
« Reply #8 on: May 04, 2013, 12:31:34 »
Thanks Mitch  :thumb:
I have various sizes of Armoured Cleats in my Man Cave, I'll have a look.
Top tip  :)
« Reply #9 on: May 04, 2013, 12:33:27 »
Juv, I don't want you thinking for a moment that I would be silly enough to go to the time, effort and cost of fitting Running Lights to my Engine Bars because there is a tiny scratch on them and I want to cover it.
That would be ludicrous  :shy:
Offline Locky
« Reply #10 on: May 04, 2013, 12:37:19 »
there's no end of clamps mouting brackets available to fit lights to crash bars ..I might even mount mine somewhere else . I'll wait till I get some new crashbars before I decide ..
Offline bat-kam
« Reply #11 on: May 04, 2013, 13:40:42 »
I have them mounted on the bars
Suzuki all the way: '98 Bandit > '99 GSX600F > '09 V Strom DL650 > '09 SV650S > '10 V Strom DL650 > '04 GSX-R 600
« Reply #12 on: May 04, 2013, 16:07:03 »
Offline Mitch
« Reply #13 on: May 04, 2013, 17:55:18 »
Fat Rat,
Do they come with a dimming module?
The might well be illegal after dark if you can't dim them down to about 30% of full brightness.
The bikevis ones I have come with an electronic module which switches them on when engine has started and turns  them off 20 seconds after the engine has been shut off. A hot wire from the rear light feed through a small rocker switch lets me change from day time running lights to night time running lights. You might not be able to use them at night. They'll be brighter than you think.
Just had a closer look. The ones in your link look to be the bikevis V2 cree lights only without the control unit.
Offline putbinoot
« Reply #14 on: May 04, 2013, 19:59:29 »
Quote from: "Fat Rat"
£9.50 delivered  :shock:
http://www.ebay.co.uk/itm/PAIR-4-LED-12 ... 337dac3e8d
Man after my own heart, I see you went for the expensive ones.
« Reply #15 on: May 04, 2013, 20:42:41 »
Quote from: "putbinoot"
your Tax is out  :angry-tappingfoot:
Offline Locky
« Reply #16 on: May 04, 2013, 21:06:01 »
Tax is free for an Ocean going bike  lol
« Reply #17 on: May 04, 2013, 21:16:13 »
you trying to say something?
just because I plan for the worst :shrug:
« Reply #18 on: May 05, 2013, 00:34:47 »
It might just be an old picture :)
Offline putbinoot
« Reply #19 on: May 05, 2013, 12:18:07 »
