The Argos thirty quid type proved utterly pointless, needed calibrating every time they were used even on the same setting. Snap-on wrenches held for over 500 uses, but the scales were out so practically every time you used them on a different bolt you should have them on the meter. Electronic torque cells held for thousands of uses, so calibrated once a year in most uses.
Andy
