A few weeks back, the speedo just stopped working. It cycles up along with the rev counter when the ignition is turned on, but reads zero mph when I take the bike out.
Prior to this fault, I had took the bike out for a ride, come back, washed it and put it away for a few days.
I followed some instructions from th international site on how to take off the panels to access the plug under he LHS front fairing panel, and it looks dry and in good condition. I also followed the cabling up from the lhs of the front wheel to see if any of the tie wraps wee especially tight but they seemed okay.
I had the tank off and it looks like the cable disappears somewhere beneath the air filter box.
What do you recommend next? Do I need to get the airbox off to access the plug, then get a multimeter on it?
If so, are there any instructions on removing the airbox, and on how to test with a multimeter.
From what I have read, this year (2007) are prone to speedo sensor failure.
