Author Topic: Need help urgent !!  (Read 2156 times)
Offline chalky
Re: Need help urgent !!
« Reply #20 on: April 19, 2013, 20:53:54 »
Quote from: "Strommer"
You do have a gasket on the non oem air filter don't you?
first thing I asked him!
SUZUK DL650 2005, KAWASAKI KDX 200 1998, Honda C110 1963, Honda CD90Z 1972
Offline Greggio
« Reply #21 on: April 20, 2013, 11:54:41 »
:bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:  :bawl:
2005 blue vee. 1972 Yamaha yg1. 1988 Honda camino. 1982 Honda camino. 1964 puch maxi. 1985 tomos. And a partridge in a pair tree.
Offline Strommer
« Reply #22 on: April 20, 2013, 15:37:40 »
.....Italian tune-up could be in order.... :shy:
A disgrace to biking...
Offline Firestorm
« Reply #23 on: April 20, 2013, 16:46:19 »
This sounds like it could be a vacuum/air problem. This is a long shot and I'm sure you've checked but ...are both nipples for throttle body balancing still fitted and secure? If one is loose or missing it will cause the issue you have particularly at smaller throttle openings.
Offline Greggio
« Reply #24 on: April 20, 2013, 16:51:34 »
Just Checked valves front cylinder inlet 0.15 0.10 ex 0.20 0.20    rear cylinder inlet 0.15 0.15 ex 0.20 0.20
Front cylinder compression test 145psi     Rear cylinder compression test 155psi  all electrics are now soldered instead of crimped got new plugs and genuine air filter all fuel lines have been blown out all injector seals checked so I'm going to build it up and drain the tank and clean the pump filter put fresh juice is and I've got a put online additive to put in and if its still no different then it must be my imagination lol
Offline Greggio
« Reply #25 on: April 20, 2013, 17:00:02 »
Quote from: "Firestorm"
Do you know what firestorm you have got me thinking I have checked the nipples but one of them has my scottoiler plugged into it maybe it could be drawing air in through the oiler somehow I think I might disconnect it and see
Offline Firestorm
« Reply #26 on: April 20, 2013, 17:39:03 »
Its well worth a try. Good Luck and here's hoping for an easy fix.
Offline Bumhead
« Reply #27 on: April 21, 2013, 16:06:04 »
PM sent  :thumb:
I am not a complete idiot.............Parts of me are missing
Offline Firestorm
« Reply #28 on: April 28, 2013, 19:13:50 »
Greggio - did you get this sorted?
Offline Greggio
« Reply #29 on: April 28, 2013, 20:05:05 »
I did indeed turned out to be a faulty throttle position sensor but it took some finding as it didn't register a code on the dash and I only found it when I tried to adjust it at running temp while the bike was idling all other tests on it turned out OK. But the fact I now know my dl inside and out for further issues is an added bonus  :fix:
Offline Firestorm
« Reply #30 on: April 29, 2013, 18:56:39 »
Great stuff! All's well that ends well.
