I'm with greywolf here , check the airbox is all tightened on properly. If it isn't , the bike won't have the same compression as before and will cause problems like you are experiencing. Check all the little rubber seal is where it should be too,
I had the same problem with the XT at one point... Although there was a strong smell of cow dung when I did...
