Self inflicted as most of my problems are.
I fitted new brake lines, pads, pistons and seals.
Now one of the bleed nipples is leaking through the thread.
Not pouring out just weeping.
It did this overnight when no pressure was applied.
It is not leaking up through the bleed hole (but that may be because the fluid is leaking through the thread first).
I thought screwing down the bleed nipple closed off the bleed hole so I can't see how the fluid gets to the thread.
I have tried loosening and tightening the nipple in case it was not seating but this has not cured it.
Anyone had this problem and or can suggest a fix?
