Author Topic: anyone help to find a 12v socket like this?  (Read 1043 times)
Offline thebigcheese
« on: March 03, 2013, 22:13:58 »
found a usb charging socket that you can screw charging leads onto so it stays 100% waterproof wile in use. what I want is a 12v socket version of this usb one that can screw the charging leads onto. does such a thing exist? link below of the usb one
http://www.powerlinkproducts.co.uk/usba ... ocket.html
or am I going overkill on this and just stick a normal 12v charger on and a drop of acf50 on it.
bikeless
Offline White Hart Paul
Re: anyone help to find a 12v socket like this?
« Reply #1 on: March 03, 2013, 22:25:39 »
I bought this
http://www.ebay.co.uk/itm/12v-Motorcycl ... 58966312a1
works well and easy to fit
Paul
New Biker, late developer I guess.....But doing my first
Tour of Europe this June... Yeeehaaaaa
« Reply #2 on: March 03, 2013, 22:54:22 »
cheers, I am looking a 12v cigarette type charger though. but was wanting to know if there was one that had the screw on charging leads like that usb charger in the link
bikeless
Offline DesertStrom
  • Bike: DL650 K9, Triumph Street Scrambler
« Reply #4 on: March 04, 2013, 10:55:02 »
No I want the charging cable to screw onto the front of the charger. from the charger to whatever device it is your charging. just like the one in the link.
bikeless
Offline putbinoot
« Reply #5 on: March 04, 2013, 14:00:14 »
Quote from: "thebigcheese"
Any panel waterproof socket and plug would work , napkins may do them or SN electrical wholesaler or marine supply shop.
http://www.gaelforcemarine.co.uk/36365/ ... rious.html
Offline Fatbelly
« Reply #6 on: March 04, 2013, 15:39:40 »
To: thebigcheese
Don't worry it's not your fault. You have not suddenly lost the ability to use the English language.
I don't know either why these folks are not reading the question but trying instead to answer the question in their heads. To me it's obvious; you need it to be waterproof WHILE IT'S CONNECTED. Easy peasy.
Having said that, sorry I can't help.
« Reply #7 on: March 04, 2013, 15:51:00 »
Ha ha. yeh that's it spot on mate. Have tried looking for a 12v cigarette style socket with screw on threads at the front to screw on a charging cable, just like the usb one in the link. Dosnt have to be screw on, just so that the connection remains waterproof when you are using it. obviously the screw on connection is more secure and the charging cable can't pull out
bikeless
Offline putbinoot
« Reply #8 on: April 16, 2013, 23:41:50 »
Unless I'm mistaken the one in my link is waterproof in use.
« Reply #9 on: April 16, 2013, 23:52:11 »
Waterproof is not a big deal for simple electrical connections. 12V DC wiring can be done under fresh water. It's electronics and semiconductors that have to be protected. The handlebar switches on the bike are not waterproof and they usually work fine. Dissimilar metals in a wet environment can corrode by galvanic action though.
« Reply #10 on: April 17, 2013, 08:43:53 »
+1 what Greywolf said.
I never did find one that looked entirely waterproof while in use. But it really doesn't matter too much, for the reasons above.IMO.
This is what I got, with a matching socket from the same supplier, they click together and allow very little water in while in use (I plug my car sat-nav in, and no problems in some truly torrential rain). More water gets in when I wash the bike, just a matter of a quick dry with a cloth after.
Offline jimbo8098
« Reply #11 on: April 17, 2013, 13:42:31 »
I got one off ebay for £5 by buying the terminals for £3 and a fuse holder and fuses which came to another £2. Got some spare wire to extend it over to my battery and done. Zip tied it under my seat with a bit of old school jumper so it dosen't mark the paint. I think that I will switch it out to a genuine one for peace of mind though :)
