Author Topic: Replacement Brake Pads - Any Recommendations?  (Read 3130 times)
Re: Replacement Brake Pads - Any Recommendations?
« Reply #20 on: February 18, 2013, 16:14:09 »
Quote from: "kennydies"
Are they all the same pads for a DL1000 and 650?
Yes.
Offline Descolada
« Reply #21 on: February 19, 2013, 15:11:50 »
Quote from: "Descolada"
Quote from: "Sven"
FA229HH & FA231HH are the fronts
FA174HH are rears
Thanks for the information, appreciated.
Ordered the EBC HH fronts in the end. Thanks everyone.
Offline Rasher
« Reply #22 on: February 19, 2013, 20:14:19 »
I normally find most top brands are OK and just avoid cheap tat.
SBS are very good, they are recommended by PFM who make the most wonderful brake discs (Hizzy used to use PFM Discs on some of his IOM bikes)
Offline bat-kam
« Reply #23 on: April 08, 2013, 22:27:20 »
I have just ordered set for pront and back EBC HH pads.
Front ones are have only few mm life left on them  :shy:
Suzuki all the way: '98 Bandit > '99 GSX600F > '09 V Strom DL650 > '09 SV650S > '10 V Strom DL650 > '04 GSX-R 600
Offline bat-kam
« Reply #24 on: April 11, 2013, 22:43:25 »
So after an hour this afternoon I have full new set of EBC pads. And it was just as well as the from left pads have nearly gone to ZERO.
The left side was slightly better:
The rear was in the best condition but as I was replacing front I thought I will do the rear too.
It was a good thing that I have the retracting tool for brake callipers that I bought ages ago when changing pads on my rusty Honda accord.
And I had no problem with pins - they came out nice and easy. When putting things back together I used lots of copper grease.
I had to take her for a ride. Few corners and crossroads and the difference is huge!!!  I did not realise hid bad my brakes were. I wonder how much more improvement would the braided lines would make. And new DOT4.
The old pads were
Front - TOKICO
Rear - NISIN
Both made out of lard hahaha
Kam
Offline mr_mal
« Reply #25 on: April 12, 2013, 00:15:13 »
Quote from: "greywolf"
...The stock pads on my '12 Glee feel much the same as as the EBCs on my old Wee.
Hmmm... Wondering if HH pads would be any improvement on an L2 then?
Haven't been happy with my brakes (especially 2 up) since I took out a tiger xc. I don't want to go down the route of braided cables etc at the mo yet though...
Offline willbo
  • crazy is contagious
  • Bike: 2010 dl650x
« Reply #26 on: April 14, 2013, 22:23:15 »
been checking up online and using the owners manual and I feel confident I can do my pad change when they arrive. Just a quick question though. Some people recommend using red rubber grease after cleaning around the pistons just to help the seals. Do you blokes do that when servicing your calipers or just clean the calipers with soapy water and a tooth brush and leave it ?
Offline Jacko
« Reply #27 on: April 19, 2013, 11:01:24 »
I use brake cleaner and a toothbrush on the pistons and other components (wire wool on the pins etc.)and then use a cotton bud to apply some ACF50 to the pistons then push them back in.. Folk say that ACF50 is detrimental to the seals but I've been doing it for years with no ill affects, keeping the brakes serviceable and in good condition through many winters.. Even on the notoriously finicky Tokico six pots on my zx6.. Red rubber grease on the pistons will protect them too..
Changing pads is a maintenance job, it's fairly simple and in no way beyond even the most inexperienced home mechanic. Just take your time and enjoy it, really. There's nothing more satisfying than keeping your bike in serviceable condition by your own hand..
Offline willbo
  • Bike: 2010 dl650x
« Reply #28 on: April 19, 2013, 17:52:12 »
feeling like a proper man again now. Managed to clean and change my rear brake pad set . wasn't all that hard truth be told. The old ones were caked on the back with copper grease from the dealer so I copied that. Everything seems to be working great
Edit: changed the front ones too after dinner. Even easier than the back one. Removed the lil pin, all just came out easy. Cleaned and placed the sintered hh inside  just like back. Looking forward to trying them out
Offline cabra
  • Bike: 1995 Triumph Trident - 1976 Triumph Trident - 2011 Ducati Multistrada 1200s
« Reply #29 on: June 10, 2013, 23:56:51 »
This is a quote by sven previously in this thread.
"FA229HH & FA231HH are the fronts"
As both are listed as DL1000 front pads,
what is the difference in the two part numbers?
OK - Brain fade, forget the above.  :obscene-drinkingchug:
Offline jackie_black
« Reply #30 on: June 11, 2013, 07:13:15 »
I think I'll get HH pads fitted at my running in service, would like a little more initial feel from the brakes.
Offline willbo
  • Bike: 2010 dl650x
« Reply #31 on: June 11, 2013, 10:47:17 »
I have ebc hh sintered pads all round. they work great and give me a super feel on the brakes. I have abs though so locking isn't a problem. some go for hh sintered front and ebc organic back which tend to give a little less harsh braking as some would say.
whatever ones you get, most tend to go for ebc pads
