F1 on dash ,any ideas ?
Topic: F1 on dash ,any ideas ? (Read 703 times)
nt1
February 01, 2013, 15:46:47 »
Hi folks,
I have a 2010 WEE with 18k miles on it that on a few occasions in the last six months ( about 6k miles) has displayed F1 on the dash when I initially turn the ignition on . There's also no sound from the fuel pump but if I turn the ignition off then start again everything's fine. Any ideas ,is this anything to be concerned about ?
Thanks for any advice.
Neil
greywolf
Re: F1 on dash ,any ideas ?
February 01, 2013, 17:23:01 »
When the FI is displayed, use the spare key to get under the seat and jumper the dealer mode connector to read the trouble code.
http://www.vstrom.info/Smf/index.php/topic,7061.0.html
Trouble starting as you described is often a C42 code that means the resistance read off the ignition switch is out of range. A marginal contact in the switch or wire connection to the switch is commonly the problem if you read a C42.
nt1
February 02, 2013, 07:44:36 »
Thanks very much for that Greywolf !
Fatbelly
February 02, 2013, 18:30:10 »
Nice avatar Greywolf. Is that a plate in your left wrist?
greywolf
February 02, 2013, 18:36:32 »
I have plates in my left hand and wrist. That the animated wolf I found has bionics in about the same place is an interesting coincidence.
