Author Topic: Gaitors to front forks  (Read 1533 times)
Offline shameless_frank
« on: January 08, 2013, 18:39:06 »
Has anyone managed to fit rubber gaitors to the front forks to protect them?  I'm thinking of finding some to fit them to my glee.
Re: Gaitors to front forks
« Reply #1 on: January 08, 2013, 18:50:41 »
I have Rancho RS1952 boots installed. Since I have a fork brace on a lowered bike. I cut off the bottom at the third pleat to sit on the brace. No brace - no cut. Brace on a non lowered bike, 2nd pleat. Be aware the fork travel may be reduced slightly.
Offline Jeff999
« Reply #2 on: January 08, 2013, 19:38:23 »
Is it a major job to put the gaiters on, do you have to remove the forks? Please excuse my lack of knowledge.  :shrug:
Offline Locky
« Reply #3 on: January 08, 2013, 19:48:27 »
Yes they have to be removed but its quite a quick and easy job .
« Reply #4 on: January 08, 2013, 20:35:56 »
Just be aware the bolts on the Glee forks that hold the fenders on are attached with thread locker. Just applying more force will spin the steel plates in the plastic mudguard and damage the mudguard. The plates have to be kept from spinning. I left the mudguard attached and removed the entire front end after taking off the wheel and calipers to install the boots. If that feels like too much work, wrap around fork protectors from NOJ are an alternative. http://www.ebay.co.uk/itm/NOJ-Fork-Guar ... 0567873040
Offline Jeff999
« Reply #5 on: January 08, 2013, 21:17:45 »
Thanks for that Greywolf. I think that may have to wait until I find someone who knows what to do. Or give guidance.
Offline Locky
« Reply #6 on: January 08, 2013, 21:30:37 »
Got these on mine , they fit perfect  http://www.ebay.co.uk/itm/TRIUMPH-BSA-N ... 7873040%26
« Reply #7 on: January 14, 2013, 19:41:08 »
Has anyone done a step-by-step guide or even just pics as to which bolts to undo on my glee? Just asking as would be v handy :)
Offline Jeff999
« Reply #8 on: January 14, 2013, 19:48:08 »
+1 for that suggestion..
Offline cabra
  • Bike: 1995 Triumph Trident - 1976 Triumph Trident - 2011 Ducati Multistrada 1200s
« Reply #9 on: January 14, 2013, 20:19:24 »
Quote from: "shameless_frank"
Check this out
viewtopic.php?f=58&t=13924
« Reply #10 on: January 14, 2013, 21:40:36 »
Cheers Cabra, I've asked a question on this (sorry if over complicating this just don't want to cock it up) on the thread you posted, can you have a squiz and let me know the answer?
Offline Locky
« Reply #11 on: January 14, 2013, 21:55:59 »
Might be worth buying the gaitors and taking to a local bike shop , they should do it in a hour at the most .
