Author Topic: Check your DL1000 wiring diagrams  (Read 781 times)
« on: January 06, 2013, 17:58:49 »
There is a misplaced connection dot in the fuse box of wiring diagrams I've seen for K4 and K5 DL1000s. The K3 was okay. I've put a green dot where the connection appears in the manual. That spot should be a crossover. The connection should be where I've added a red dot. (on the left for the colorblind). The common wire feed to those fuses should be the orange wire.
