here is the bullet on the side of the handguard. held on with tape during installation. (need to get alcohol wipe to clean the service to get it to stick good and proper)
very limited space to put it on handguard really. was going to put in on the underside of the handguard but not enough of the handguard to stick it too. so had to stick them on the side in the end. the cable will run along the inside of the guard and gets tied in with the bikes wiring loom then. neat enough act.
this is where I put the pos-tap. (rough looking as I just connected it up to test all the soldering held up and worked OK
) the left hand panel came off and its there in front of you. I was able to change both sidelights with taking the one panel off (just turned the steering round too full lock each way to give myself more arm room to change the bulbs). not hard, just fidly and time consuming.
