The white striped wire is positive on the bullets. Connect it to the brown wire on the bike if you want it to be on when using the park position on the ignition switch. If you want it to be off in the park position, connect it to the orange/green wire. If you don't use the park position on the ignition switch, either brown or orange/green will do. Ignore any coloured dots on the wires. They are not part of the colour code.
Connect the all black wire on the bullet to a black wire with a white stripe on the bike. As I said, all those wires are available at a large connector in the left side of the fairing.
