Author Topic: clutch lever switch  (Read 829 times)
Offline CSE1
clutch lever switch
« on: September 15, 2012, 21:05:08 »
Hi there
If the switch is faulty is it possible to bridge across the 2 female spade connectors to start the  bike while a new one is ordered?
 Many  thanks
Gas Gas TXT250 PRO, Yamaha XT350, Kawasaki ER6F ('ers)
Offline LaKraven
Re: clutch lever switch
« Reply #1 on: September 15, 2012, 22:00:40 »
It's just a two-pole push switch, so yes... bridging the two connectors should work just fine!
EDIT: Though I've no idea what the bike will do with the circuit connected the entire time while riding! Should be fine, but to me that's uncharted territory!
Black DL650AK9 GT, 09 reg: 1" lower front and rear, USB charging and lighter sockets, Madstad bracket, Slipscreen and large Givi screens (for purpose), Aux Light Bar, fog lights (switched), custom ignition-switched wiring loom
« Reply #2 on: September 15, 2012, 22:13:57 »
That's fine except for 2007(K7) and later 650s which use the clutch lever switch as part of the info sent to the ECM. Earlier 650s and all 1000s so far are okay with bypassing the switch.
Offline LaKraven
« Reply #3 on: September 15, 2012, 22:18:44 »
Quote from: "greywolf"
I've written that one down just in case I ever have a problem with that switch! Good to know, thanks!  :thumb:
Offline Locky
« Reply #4 on: September 15, 2012, 22:37:37 »
New switch from here http://www.ebay.co.uk/itm/Suzuki-DL-100 ... 3cc43d3ebb  had one for my 650 from these with good service .
