Author Topic: Touratech Fog Lights  (Read 1996 times)
Offline mg2959
« on: September 12, 2012, 09:12:53 »
Hello,
Has anyone had experience of the following? Fitting/ownership etc.
http://shop.touratech.co.uk/fog-headlig ... l-650.html
I like the look of them and the fact that they attach to a bracket that actually fits to the fairing, rather than attach to a crash bar. However I don't like the wiring option, it looks like you just pass the cabling over the fairing down past the stock and behind the radiator. Does anyone see an issue with making a small mod of a hole in one of the fairing panels to pass the cabling through - may be then cable tie it to the inside and neatly cable it in behind the radiator thus hiding the ugly cable?!?
Offline Sharpy
Re: Touratech Fog Lights
« Reply #1 on: September 12, 2012, 09:28:28 »
No experience with these but £148 for a single light?  Wow!  They must be great!!
Biker & Cyclist...
Offline mg2959
« Reply #2 on: September 12, 2012, 09:33:47 »
Yeah agreed, they're not cheap! But probably the best looking and best placement on the wee that I've seen.
Offline bat-kam
« Reply #3 on: September 12, 2012, 13:37:34 »
I have been given some daytime LED ridig/driving lights that cost £90 for a pair. My mate has the same on hos bike mounted on the rad guard. I hven't got one and trying to find a way to mount then to crash bars. Any ideas?  Those turatech do look nice, but the price is a killer for me
Suzuki all the way: '98 Bandit > '99 GSX600F > '09 V Strom DL650 > '09 SV650S > '10 V Strom DL650 > '04 GSX-R 600
Offline eagle6
« Reply #4 on: September 12, 2012, 13:58:35 »
These are a better option:
http://www.bikevis.com/motorcycle-cree-led-running-lights.html
Lower power drain, and wire direct to battery with built in electronic power on/ off
Offline bat-kam
« Reply #5 on: September 12, 2012, 14:11:53 »
These are the same ones that I was given. Was told that they cost £90 :(;). What a friend.
Has anyone mounted then on the crash bars?
Offline Strommer
« Reply #6 on: September 12, 2012, 14:13:35 »
Quote from: "eagle6"
I have these, they are bright as flump but they don't cast a beam, so no good as a fog/driving lamp, great as a running light - if a bit flimsy.
A disgrace to biking...
Offline PHIL FAT
« Reply #7 on: September 12, 2012, 19:09:18 »
got mine from a company called chainspeed £149 for 2 fitted them to the crash bars and easy to install you can see them on my avitar
Too Old To Die Young
Offline Strommer
« Reply #8 on: September 12, 2012, 19:19:35 »
They're 110watts the pair - which is quite a load.  These are good and much cheaper and 15 watts.   http://www.bikevis.com/motorcycle-rigid-industries-duallys.html
Offline bat-kam
« Reply #9 on: September 12, 2012, 19:23:35 »
Phil,
Could you do close up picture, please?
Thanks
Offline Sven
« Reply #10 on: September 12, 2012, 19:46:12 »
Some people have had problems when fitting extra lamps which are quite high wattage. The alternator output on the v-strom is not that high ( about 375-425w IIRC). If you fit these & you run some other extras such as heated grips/clothing, etc, you may find it has not got enough power to run them all.
that's why LED's are a favourite with most on here.
Have a look here
viewtopic.php?f=50&t=5854
He fitted 55w lights but then had to change the bulbs to LED's
Offline raggydan
« Reply #11 on: September 12, 2012, 20:16:34 »
I keep plugging them on here but the Vision X LED ones I bought are superb, very bright, solidly built
and most importantly,only 10watt draw per light.
don't waste your money on overpriced touratech gear.
http://www.adventure-spec.com/default/l ... -solo.html
Offline mg2959
« Reply #12 on: September 12, 2012, 20:31:11 »
Quote from: "raggydan"
Thanks everyone for your opinions and advice.
I like the look of these ones raggydan. Where would you mount these on the wee?
Offline raggydan
« Reply #13 on: September 12, 2012, 21:00:49 »
I had them mounted on a pat walsh lightbar just under the nose fairing, but have since moved
them to just above the indicators attatched directly onto the fairing.
I'll post a pic if you want(tomorrow).
Offline mg2959
« Reply #14 on: September 12, 2012, 21:07:19 »
Picture would be great mate cheers.
