Author Topic: Paint flaking off rad in big lumps  (Read 737 times)
Offline ilkleyal
« on: September 11, 2012, 22:47:44 »
Anyone recommend me a good treatment? there are large bits of paint flaking off the Aly rad tank on the left side. I will live with it until the winter when I'm sorry to say, I hang up my leathers for most of the dark cold months and I will strip it then for re-paint as part of a mega service.  ah, but what to repaint it with?
Bike lives a charmed life in a heated garage so I'm in no rush, it won't get any worse but it does spoil the bike a little.
Al
Offline Coval
Re: Paint flaking off rad in big lumps
« Reply #1 on: September 12, 2012, 09:14:02 »
I use black satin (matt-ish) Hammerite paint to deal with minor chips and flakes.
Sticks to metal like glue, is very tough and has some corrosion inhibitor in it.
Spraying small areas isn't often possible so I dab the affected spot with a sponge pad or an old toothbrush couple of times, an hour or so apart. Loose debis needs to be scaped off first of course.
Piaggio X9 250 > Kawa GPZ900R > Yam GTS1000 > Yam TDM900 > Yam FJR1300 > K7 Wee & '98 VFR800Fi
Offline ilkleyal
« Reply #2 on: September 13, 2012, 05:48:55 »
Yes, I began scraping the loose bits off and have an almost bare rad tank now :shock:
I will use the stuff you mention. At least it will cure a bit faster than it normally does by being on the rad.
Al.
Offline Strommer
« Reply #3 on: September 16, 2012, 08:25:14 »
Been painting my stove pipe with Wickes heatproof metal spray (matt).  Would leave a nicer finish than hammerite.
A disgrace to biking...
Offline Locky
« Reply #4 on: September 16, 2012, 09:20:26 »
I used this http://www.plasti-kote.co.uk/Idea/icode---5262  also used on exhuasts in the past and it stayed on . Nice finish too .
Offline 2112
« Reply #5 on: September 16, 2012, 12:28:58 »
+1 for the plasti-cote, it gives a pro finish for bungling amatuers....  :shy:
