Hello all,
I'm Martin and live in Hampshire. I have a 2008 DL650 in black, which I have owned since new. I use it mainly for my 70 mile commute on a daily basis. Currently have 33k on the clock.
I found this forum by searching the net for a problem I have. Probably should post this elsewhere in the forum, but as I'm new here I'm sure you nice people will let me off?
I have intermitent indicators, no left indicator, some right indicator, no 4 way hazzards. I've looked at the fuse, bulbs, left hand bar switch gear, and my thought process was it must be a switch or connection issue somewhere as it works sometimes.
So I looked on the net and found some of our V-Strom buddies in the States that harped on about a difficult to reach yellow switch connector block positioned behind the radiator. So I've stripped the bike down, all fairings, fuel tank and airbox ... (Seems mental for an indicator problem) and have found the said block ..... anyway ... it all looks fine to me .... what do I need to do, strip it and check connections? Clean, WD40 it?
Anyway cheers in advance
Martin
