Author Topic: Speedo sensor location?  (Read 1737 times)
Offline Big Al wi the Vee
« on: July 11, 2012, 08:31:29 »
I changed my Chain & Sprockets on my 08 Vee last night and this morning have noticed that my speedometer is 15 miles lower than it should be ( 45 in a 30 )!
Can anyone point me in the direction of where I should be making adjustments to get this back on track please?
 :fix:
Offline 73bm73
Re: Speedo sensor location?
« Reply #1 on: July 11, 2012, 09:08:56 »
adjustments... hmmm...
are you using a different ratio now? If yes, a 'speedo healer' will help.
If no, have you fixed the speed sensor correctly? It's positioned on the sprocket cover.
« Reply #2 on: July 11, 2012, 09:36:27 »
Berndi,
I don't think I have fitted it correctly, to tell the truth, I stood behind my mate while he did all the manual work holding the coffee :)
I didn't notice if he had done anything wrong, but there were no bits left over so it must be right :grin:
Although, I did notice that he did tighten the sensor fitting with an extra bit of leverage, normally I would fit it hand tight since it doesn't have any stresses put on it that may make it go loose.
BTW: The Sun is out now :violence-uzi:
Offline 73bm73
« Reply #3 on: July 11, 2012, 10:02:35 »
do you still have the 17/41 ratio?
« Reply #4 on: July 11, 2012, 10:03:42 »
Yes, Still have the correct ratio.
Offline 73bm73
« Reply #5 on: July 11, 2012, 10:16:26 »
remove the speedsensor again and clean it. And remove the sprocket cover and clean the counter piece (in english...?), too.
If it still doesn't work after this, perhaps the sensor or the sensor wire is broken or the wire plug ( under the left fairing) is dirty/wet.
(Hope, you understand what I mean... :shy: )
« Reply #6 on: July 11, 2012, 10:30:20 »
Thanks Berndi, I'll give it a check later, unfortunately work gets in the way just now. :)))
« Reply #7 on: July 11, 2012, 14:31:52 »
The speedo sensor is on the end of the front sprocket countershaft. It is a Hall Effect magnetic sensor with some poles running past a magnetic pickup. It sounds like one of the poles may have broken off.
« Reply #8 on: July 11, 2012, 15:30:27 »
:shy: Ah,  Not just one of the posts has broken off!
While removing the Front sprocket I inadvertently snapped them off with a HAMMER and BIG SCREWDRIVER lol  lol   #
Maybe I should stick to fixing Guns :violence-uzi:
Thanks for your comments blokes......  Can someone ask the Forum administrator to remove this post before too many people see it :shy:  :shy:  :shy:  :shy:  :shy:
Please :ty:
Offline Strommer
« Reply #9 on: July 11, 2012, 15:50:07 »
Quote from: "Big Al wi the Vee"
Please :ty:
Too late....
Oi!  Over 'ere!  Get a load of this everyone!!!!    :fix:
A disgrace to biking...
« Reply #10 on: July 11, 2012, 15:55:53 »
the clarkson school of hammer fixing stuff.
« Reply #11 on: July 11, 2012, 16:02:58 »
If you look over in the wanted section I'm looking for a 2nd hand speed sensor!
 :shy:  :shy:  :shock:  :shock:
It's great being thick skinned and Fick as Thuck :neen:
« Reply #12 on: July 11, 2012, 17:06:18 »
Now I understand your concern over whether the forks have to come off to install gaiters. I have notified Interpol and they are coming to confiscate your tools.  :grin:
Offline Ptarmigan
  • Bike: CRF1000 Africa Twin
« Reply #13 on: July 11, 2012, 19:24:17 »
Thanks Big Al for the biggest laugh of my day!  lol  lol  lol  lol  lol
Good on Your fer fessing up too. I suspect many on here would, like myself, have feigned ignorance..... :shrug:
Good luck finding a replacement. :thumb:
« Reply #14 on: July 11, 2012, 20:31:07 »
We could just have it moved to the humour section Big Al.
Offline whythedevilnot
« Reply #15 on: July 11, 2012, 21:05:56 »
Enjoyed reading this thread. Made me think though, my wee indicates 70mph when my gps (which agrees with the car) shows 60. I guess I'll have to take the sprocket cover off and have a look at the speed sensor jobby. I always assumed they lived on the front wheel though. Shows how much I've been paying attention.
If at first you don't succeed, try a bigger hammer.
« Reply #16 on: July 11, 2012, 21:11:17 »
The speedo sensor on the Wee is on the front axle. The speedo is about 8% optimistic when it is functioning as designed.
« Reply #17 on: July 11, 2012, 21:22:10 »
Quote from: "greywolf"
OK. Now feel even more stupid. Next time will look before I post and in the mean time, will attempt to calculate 8% as I go while accepting, there's nothing I can do about it.
Cheers greywolf.
« Reply #18 on: July 11, 2012, 21:27:52 »
Quote from: "whythedevilnot"
Cheers greywolf.
Ahem,,
You feel a bit stupid do you?
How do you think I feel :shock:
Atleast I'm keeping my mileage down to 1/3 of what it would've been lol  lol  lol  lol
You couldn't tell I was Scottish could you? :neen:
« Reply #19 on: July 11, 2012, 21:37:09 »
Just to cover all bases, the sensor on the Glee is set up like the Vee, on the countershaft. I'm told that putting a 16T countershaft sprocket on the Glee will make the speedo accurate. Too bad I tried a 16T on the old Wee and didn't like it.
