Author Topic: edit : sorted now. throttle cable too tight for risers  (Read 689 times)
Offline willbo
  • crazy is contagious
  • Bike: 2010 dl650x
« on: July 06, 2012, 16:03:47 »
hi all
some advice sought, as I'm a mechanical noob.  any chaps or ladies have risers on their wee. were your throttle cables OK after the install? I've looked at mine before installing the risers and its really tight as it is. when the 2" risers go on I doubt il be able to get full right lock. I've read posts about throttle cable adjustment, an seen pics of cables with adjusters in line, But mine doesn't, just a solid attachment to the housing.  must admit I have no idea how to reroute either because  when I had the panels off I couldn't really see much choice of a reroute to be honest
Offline Kells
Re: some advice please, throttle cable too tight for risers
« Reply #1 on: July 07, 2012, 11:26:49 »
Hi,
Just installed 2"Rox risers on 2012 wee. New brake hose 3" longer was the only new item needed.
I took off the controls on both sides & pulled back through the forks,which gave enough play on all cables including the clutch.   Works fine, just need to cable tie all back when done. No need to remove Tank.
Hope this helps.
Offline willbo
  • Bike: 2010 dl650x
« Reply #2 on: July 07, 2012, 12:15:02 »
cheers :) I should be OK then. I have the wee 2 and I've read glee has less cable length, if true lol
« Reply #3 on: July 07, 2012, 16:35:03 »
Those who have had issues just ran the cables behind the triple clamp instead of in front of it.
Offline willbo
  • Bike: 2010 dl650x
« Reply #4 on: July 07, 2012, 16:48:40 »
cheers :) had a good long look after work and I got it sorted in my head now what I need to do . Hopefully my head has it right lol
Offline willbo
  • Bike: 2010 dl650x
« Reply #5 on: July 07, 2012, 23:03:18 »
2" rox risers are now fitted along with a new brake cable. The wire extension kit from eastern beaver was very handy. Clutch cables are re routed , and while a little tighter are not at their limit by no means. All in all very pleased
