Author Topic: Help please with engine problem  (Read 1483 times)
Offline jilljoy
« on: June 17, 2012, 20:27:04 »
On my way down to silverstone my vee k7 suddenly developed a engine fault,basically the engine management /oil light came on with F1 fault.the engine started missing and would not rev without spluttering and farting.I stopped and killed the engine and restarted it ,the light went out but still sounds really sick.up to top gear it makes clunking noises and misses like hell.if it was a four cylinder bike I would describe it like it has dropped a cyclinder but I am guessing it is an air intake problem or intermittent plug or fuel injection system,but am just guessing.can anyone please advise me what I can check myself without going to the expense of taking it to a dealer.
Re: Help please with engine problem
« Reply #1 on: June 17, 2012, 20:32:10 »
The FI will provide a code that pinpoints the problem device. See http://www.vstrom.info/Smf/index.php/topic,7061.0.html
Offline thebigcheese
« Reply #2 on: June 17, 2012, 21:45:14 »
mine did something similiar on a trip. turned out it was the rear injector body to intake manifiold was not on square/sealing right and was sucking in air as a result.
viewtopic.php?f=17&t=13559
worth a visual inspection, lift the tank off and its right in front of you. simple fix if it is.
bikeless
« Reply #3 on: June 17, 2012, 21:46:26 »
That won't cause an FI.
« Reply #4 on: June 17, 2012, 21:50:05 »
Quote from: "greywolf"
apologies, missed that bit, the rest sounded familiar
bikeless
Offline jilljoy
« Reply #5 on: June 18, 2012, 18:52:19 »
I have switch the dealer block as advised and the code is c00  which says no fault code.so I am back to square one.can anyone give me an idea what to check next.I have the tank off now
« Reply #6 on: June 18, 2012, 19:29:44 »
Leave the dealer mode jumper in place until it acts up again and then the code will show. You had a soft FI that resets when the ignition is cycled. An alternative would be to have a dealer use a Suzuki SDS tool or get a HealTech OBD tool to read the past code.
Offline jilljoy
« Reply #7 on: June 18, 2012, 20:29:43 »
Thanks for your help,I am  putting 2 new plugs in and clean air filter then put it back togeather and try to get a fault code to come.problem is the code only comes on at high revs and high speed.if all else fails I will have to take it to Suzuki.I will keep you imformed
Offline jilljoy
« Reply #8 on: June 29, 2012, 13:44:51 »
Got it back togeather and still runs crap ,even on tickover
Offline jilljoy
« Reply #9 on: July 05, 2012, 17:41:55 »
I took it to a dealer last Friday,I called in today and he says that there is no fault showing on the diagnostics machine but he thinks it is a oxy sensor that is causing problems.he is looking deeper into the problem rather than changing the sensor as a new one is£250 .what's your thoughts anyone?
Offline mjc506
« Reply #10 on: July 05, 2012, 21:37:11 »
there's no way the llambda sensor should cost anywhere near that :shock:
Projects:
« Reply #11 on: July 05, 2012, 23:02:37 »
Can't yuo get an item which bypasses the sensor for about 20 quid from ebay anyway? :shrug:
« Reply #12 on: July 05, 2012, 23:07:55 »
Yeah dor whem you use an after market zorst that won't take the sensor. £20 sounds about right.
Offline jilljoy
« Reply #13 on: July 06, 2012, 12:45:20 »
He says that's how much they are but if I can find out what size resistor it needs then he can bypass it. So the question is now does anyone know what size resistor I need
Offline Abercol
  • Bike: 2016 Explorer XRT
« Reply #14 on: July 06, 2012, 13:51:51 »
An O2 sensor eliminator would be a far cheaper option.....like this one:
http://www.ebay.co.uk/itm/Oxygen-o2-sensor-eliminator-Suzuki-SV-1000-S-SV1000S-2003-2007-/261038326551?pt=UK_Motorcycle_Parts&hash=item3cc718c317
Or contact Dynojet - the power commander people, they do an eliminator for around £25 iirc.
Sheesh, it'd be cheaper to buy a power commander with the eliminator than pay the exorbitant fees the dealer wants. A replacement sensor in the USA is around $55.
« Reply #15 on: July 06, 2012, 18:04:32 »
Except for the Glee, USA Stroms don't use oxygen sensors.
