Author Topic: emissions control air valve on a vee  (Read 779 times)
Offline thebigcheese
« on: June 09, 2012, 21:53:03 »
anyone ever close the emissions control air valve on a vee? disabled the o2 sensor/lanbda sensor. just wondering how you would close the emissions control air valve and the purpose of doing so? wondering as I read this from Bsd performance's website:
http://bsd.uk.com/Suzuki-DL1000-power-c ... no-set-up/
Quote
Here’s a bike made for a Power Commander – Suzuki’s DL1000 V-Strom; not a performance bike but typical of many big V-twins. The owner wasn’t happy with its on/off snatchiness at low rpm and fitting a PC III, closing the emissions control air valve, removal of the lambda sensor and a full set-up on the Dyno made all the difference, smoothing the engine out radically.
Now, in a high gear at low rpm the engine pulls cleanly; getting rid of the lambda sensor is key – which at best is useless trundling around in traffic as it’s off/on for the catalyzer – while the PC III manages the extra fuel the engine needs (and where it needs it) nicely.
bikeless
Re: emissions control air valve on a vee
« Reply #1 on: June 10, 2012, 16:33:53 »
well from what I have found out....... the emissions control air valve, aka "PAIR Control Solenoid Valve" is the culprit for the bike snatching around 2500-3500 revs. explained in link below:
http://vstrom.info/Smf/index.php?topic=7006.0
can be fixed with A PAIR kit from the website below:
http://www.chewys-stuff.co.uk/ (Left hand menu, PAIR kit)
bikeless
