Author Topic: vee cutting out  (Read 2324 times)
Offline 1monkey1
vee cutting out
« on: May 26, 2012, 21:08:57 »
Was just wondering.
I've got a k7 vee, every now and then as I'm slowing down coming to a stop at a junction or the likes. It gives a little pop and stalls. Starts again straight away just a bit of a bummer cos you never know when its going to happen.
Any one got any ideas??
When everything is coming your way, you're in the wrong lane.
Offline temporaryescapee
Re: vee cutting out
« Reply #1 on: May 26, 2012, 22:09:08 »
Have you checked the idle speed?  I had this issue when my k7 vee was really hot - when I checked the idle was c100rpm too low.  That sorted the problem.
Offline 1monkey1
Re: vee cutting out
« Reply #2 on: May 26, 2012, 22:36:30 »
will check the idle tomorrow.
not really got the cash to go the ecu route, was thinking about running it on the higher octane petrol see if that makes a difference
Re: vee cutting out
« Reply #3 on: May 27, 2012, 08:27:53 »
My wee does it now and again. Mostly when I've been pushing her hard and am eager to go at the lights. I said usualy.... I'll manage to do it once in 3-4 months.
Did do the same thing with the old git's Honda Deauville the other week, so I'd agree its a v twin thing.
Re: vee cutting out
« Reply #4 on: May 28, 2012, 13:20:12 »
+1 on setting the idle a tad higher if it's low. If you can find a place/someone with a Yoshi box you can get the ECU tuned without having to buy a Power Commander.
Offline 1monkey1
Re: vee cutting out
« Reply #5 on: May 28, 2012, 19:42:19 »
Just been for a run and idle is abt 1100rpm.
 what's the normal rpm at tick over?
Re: vee cutting out
« Reply #6 on: May 28, 2012, 21:07:50 »
1100-1300rpm is the specified range for a Vee.
Offline 1monkey1
Re: vee cutting out
« Reply #7 on: May 28, 2012, 21:50:44 »
thanks chaps....thanks chaps.....thanks chaps....thanks chaps!!
Re: vee cutting out
« Reply #8 on: May 29, 2012, 09:37:42 »
Whereabouts are you monkey1? Kevshek (Tyneside) on here has a home-made yoshi (if I recall...)
Offline 1monkey1
Re: vee cutting out
« Reply #9 on: May 29, 2012, 21:02:06 »
I'm on the wirral.
Bit far to go but thanks, will have a phone around see how I get on.Its not a huge prob but dose rather p##ses you off when you in traffic
Offline awol72
Re: vee cutting out
« Reply #10 on: June 08, 2012, 15:10:56 »
Quote from: "1monkey1"
Was just wondering.
I had the same trouble with my k7 VEE turned up the idle and hasn't happened since
Anonymous
Re: vee cutting out
« Reply #11 on: June 08, 2012, 20:32:12 »
Whatever happens get it seen to, fast!
A local biker was killed recently coz he went to turn right in front of a speeding oncoming can, his bike cut out and he was deceased!
Don't waste time get it sorted.  :thumb:
Offline 1monkey1
Re: vee cutting out
« Reply #12 on: June 08, 2012, 21:01:27 »
Thanks for that every one, looks like I'll up the idle a bit.
Now my next question. Where abt is the screw? this is my 1st injection I've only had carb's
So instead of spending a hour or so prodding and poking on my hands and knees in the shed I would be obliged if someone could point me in the right direction.
Thanks chaps
Re: vee cutting out
« Reply #13 on: June 08, 2012, 22:28:48 »
It's on the left side of the frame.
