As the title says, and the bike's just over a year old
It's at the dealers now, and I'll post the fault when it's back, but I'll tell you the symptoms and then keep you in suspense.
Got all my gear on last Monday to go to work (lateshift), climbed on board (it's not the seat height that gets my short legs in trouble, it's the width of the seat), thumbed the starter and 'click'. My first thought was a flat battery due to the first owner wiring the grips direct to the battery and the on/off led being so hard to see in daylight. So I had to get all me bike gear off (now sweating) and jump in the car...
So next day I'm out with the jump leads, but still only getting a click from the starter relay. Volt meter on the battery shoows it's still holding over 12v, so next thing I tried was a jump lead direct to the starter motor positive (it's in the manual..) from the battery positive and still no movement. So I called the dealer, who told me it was still under Suzuki warranty and they'd come and collect it....
So if it's the starter motor, has anyone else had problems with them? It's a bit exposed on the front of the engine like that, and the positive cable hasn't got a very water-proof cover, is it a common fault?
