Author Topic: Which chain lube?  (Read 7340 times)
Offline jstrom
Re: Which chain lube?
« Reply #40 on: June 04, 2012, 18:00:53 »
I started using Wurth High Performance Dry Chain Lube a month or so ago. It really is 'dry' compared to other so called ''no fling" spray oil that I've been using. So much so that I've probably used 3times as much as the stuff that was needed. I've found myself checking it almost daily and touching it to make sure its still on the chain. Now I'm getting more used to how dry it actually is I'm feeling quite pleased. Even more impressed now after a mini(hardly any tooth brush usage) bike clean today.
Although there is still some fling, quite possibly due to the copious amounts I was putting on, its nothing compared to what I've been used to with the last lot(silver hook chain wax). The back wheel cleaned up with minimal effort and no WD40 needed!!
Overall I'm really pleased with it...
