www.v-strom.co.uk/shop
question re: updating a powercommander
Topic: question re: updating a powercommander (Read 830 times)
thebigcheese
April 05, 2012, 15:59:54 »
can you update the PC with the bike running. as you need the power to the unit and the power is only on when the bike is running (power not on when only ignition is on)
want to upload one of the maps of the dynojet website that is set up for the o2 sensor eliminated. going to save my custom map first then upload the new map.
bikeless
73bm73
Re: question re: updating a powercommander
April 05, 2012, 16:45:29 »
Which type of PC? PC-III or PC-III-usb?
Doesn't the PC-III-usb get the power from the usb cable during an update? I think so.
Ignition off(!!!) and wait a minimum of 1 minute before changing anything or disconnect a cable!! Otherwise you may damage your ECU or PC!!! (...according to the manual PC-III-usb)
so long,
Berndi
My Self Made Fork Brace - the better way to ride...
thebigcheese
April 05, 2012, 16:57:06 »
PIII 3 usb, says on the website it needs to be powered. either via 9volt power up adapter or when the unit is connected to the bike. the unit only lights up when bike is going,
bikeless
73bm73
April 05, 2012, 17:26:31 »
OK, you are right. It's too long time ago when I changed my PC map last time... sorry.
so long,
Berndi
thebigcheese
April 05, 2012, 19:56:14 »
just found out you need the bike running to update it. job done
bikeless
