Author Topic: F1 fault  (Read 630 times)
Offline mikerbull1
F1 fault
« on: April 02, 2012, 22:16:41 »
Hi, I've just bought a DL1000 and am very pleased with the bike in general except for one aspect. Unless I turn the ignition on with the kill switch on the fuel pump will not kick in and an F1 fault shows resulting in the bike not starting. If I turn the ignition on with the kill switch off and then tuen the kill switch on, the fuel pump will not kick in and the bike will not start. Is this a problem or is this just the bike and the way you need to start it. Your advice would be most appreciated. regards mike.
Re: F1 fault
« Reply #1 on: April 02, 2012, 23:09:11 »
An FI indicates a problem. Find out where the fault lies by checking http://www.vstrom.info/Smf/index.php/topic,7061.0.html
An FI is read at the normal clock position except for 2002-3 DL1000s which display at the odometer.
