question for IT guru
Topic: question for IT guru (Read 905 times)
longman
March 30, 2012, 16:45:48 »
hi
I just collected my new company laptop. the only problem is that we can't instal any software on it because I haven't got admin rights.so I came up with an idea. laptop runs win 7 and I thought I could instal linux alongside windows so when I turn it on I could choose which system I want to lunch (windows without admin rights our LINUX with full on access)
am I correct or there is something that I am not aware of that makes it impossible? thanks
Longman
Suzuki DL650 K5
Suzuki DR-Z400SM K7
Piglumps
Bike: None at this point
Re: question for it guru
March 30, 2012, 17:15:32 »
Have you tried turning it off then back on again or hitting it with something?
That's the full extent of my IT support...
Wasn't Linux one of the characters in Peanuts?
No bike at present.......
TheFamousGrouse
March 30, 2012, 18:40:21 »
That sounds reasonable enough. you just set up Linux on a different partition on the drive and choose which partition to boot from when you turn it on.
Do make sure its not a sackable offence (IT security) by tampering with your companies IT, I know I'd get my P45 if I did that to one of my works laptop.
*Insert intelligent quote here*
SimonW
Bike: DL1050XT
March 30, 2012, 19:42:05 »
Yes, you probably could, providing they haven't bit-lockered the drive (which I think would prevent you from partitioning it). Would be better to get them to give you local admin rights to Windows. Find a friendly one and ask.
Strommer
March 30, 2012, 19:50:46 »
Stick linux on a memory stick and run it from that. No need to install anything. You can even install software on the stick. Ubuntu 10.0.4 seems stable.
A disgrace to biking...
longman
Reply #5 on:
March 30, 2012, 21:26:42 »
thank you blokes, I will do some more research and try some solutions you mentioned liek usb stick, thanks
Longman
Suzuki DL650 K5
Suzuki DR-Z400SM K7
Juvecu
Eat, Sleep, Ride, Repeat
Bike: '11 Versys 650 & '05 TT-R250
Re: question for IT guru
Reply #6 on:
April 02, 2012, 17:29:02 »
Poke me when you have time and I can help you with sorting out the best solution, I used to configure and install Linux servers for a living when I was still in South Africa.
Members Map
Juv's Strom "Restoration" (sold to Mad Phil)
Juv & Locky's Morocco Trip Report
Juv's Blog
