Author Topic: More Reliable Brakes....?  (Read 2618 times)
Offline Strommer
Re: More Reliable Brakes....?
« Reply #20 on: March 28, 2012, 08:06:07 »
They're pretty bad - though only on the outside ring.  I'll clean them up in the next month or so then report back, off on holiday next week.
A disgrace to biking...
« Reply #21 on: March 28, 2012, 10:21:44 »
If you think you can sand it down with fine water paper (1500 grain or so) then they might be usable for a while yet. Pics would help to tell if they are salvageable or not worth the effort. For the price of new ones though I'd give it a good go :thumb:
Offline Ubique
« Reply #22 on: April 06, 2012, 09:54:47 »
Juv,
When you clean your calipers do you take the whole caliper off the bike?
ie: Clamp the hose, remove the hose from the caliper?
Offline Strommer
« Reply #23 on: April 11, 2012, 12:28:13 »
OK, been busy with the Big Syringe.  Still no luck..... off to the local bike shop tomorrow.
Defeated.   :bawl:
« Reply #24 on: April 11, 2012, 18:03:10 »
Yep, whole thing off so I can work on the bench (or stainless steel trolley in my case.) I don't bother clamping the hose, I just let the fluid drain off into pan or something then use that for the initial cleaning.
Strommer, you can push feed it too if you like, just remember to suck some out of the reservoir before it overflows each time. I've not done it this way though, sucking works for me.
Offline Strommer
« Reply #25 on: April 11, 2012, 18:43:29 »
Yeh, push feed was next on the list but I've run out of time and patience.
