Here's a copy of what I wrote when I done it.
Well, today I did it the 'lazy way'. Had a set of Hagon fork springs to fit & fork oil to change. Done it all out the top without removing the forks (as per my earlier post which was taken from SV650.org).
Had to loosen the handlebars to give enough room to remove the springs - otherwise was all very straight-forward.
Loosen caps, jack up front of bike, undo handlebars & remove caps from top of forks.
Remove spacer, washer & spring. (used a length of wire to remove spring)
Drain oil using a length of pipe & syringe. (Measured old oil & got about 475ml out of each leg).
Lifted front wheel to compress forks & re-filled with oil (to an air-gap of 150mm).
Replaced (Hagon) springs, washer, spacer & caps. Re-fitted handlebars.
Job done: total time taken about 1 hour 15 mins.
I had a litre of new oil & had a small amount left over. Each fork should take 524ml of oil. So there was a bit of old oil that I couldn't get out. But I managed to replace 95% so I'm fairly happy.
Obviously to do the job properly you need to remove the forks but I'm happy with what I've done.
Only had time for a quick run up the road, but the front end feels so much better. I'm very pleased with it
Here's the link to the full thread
viewtopic.php?f=24&t=7911
