Author Topic: What have you done with your V-Strom today?  (Read 1738629 times)
0 Members and 11 Guests are viewing this topic.
Offline Sage
  • Bike: DL650 K6
« Reply #9320 on: January 16, 2020, 22:43:26 »
Ah, and here at far south we don't have biking seasons.
You lucky chap, was down in the SW corner of Portugal a couple of years ago...great riding and different than the NE.
Offline crazyhorse
  • Bike: DL800RE M4
« Reply #9321 on: January 16, 2020, 23:28:03 »
Hi
Fitted a couple of ammo boxes to my Dakar pannier frames, and it looks OK.
Tried to fit the boxes behind the bike, but it slightly affected the handling, but carrying capacity could not be beaten.
Crazyhorse
Offline SimStrom
  • Bike: DL650 K7, 2016 Triumph Bonneville T120, 2011 BMW R1200RT, GasGas 200TXT, 2016 BMW R1200GS
« Reply #9322 on: January 19, 2020, 18:06:50 »
Took it on a jaunt round Derbyshire. It was nice once the sun showed its face  :sunny:
This message was sent from my 650's on'board computer system
Offline Asmith61
« Reply #9323 on: January 19, 2020, 20:16:15 »
Nice pic and the sun was out  :thumb:
Offline himaro
« Reply #9324 on: January 20, 2020, 15:02:23 »
First time riding since my knee operation at the start of December. Bloody freezing ride back into work. Felt great riding again though.
I think my handlebars are slightly bent from when the bike blew over in the wind. Not badly and can probably be left alone, but either way, tempted to replace with a set of renthals or something. Any recommendations for bars with extra utility for adding bits on like satnav mount, heated grip controllers etc etc?
A month and a half under a cover meant my chain needs a good clean because of the surface rust... Bit of a pest but meh.
Offline Dark-Strom
  • Bike: 2018 Ducati Scrambler 800
« Reply #9325 on: January 25, 2020, 17:51:33 »
Turned the bike around to prevent bearing flat spots, replaced a panel pin on the tail fairing near the grab rail as well as fitting a webbed seat cover to hopefully improve comfort.
(Not much, but it was 4 degrees in the bike cave :fix:)
Offline hotbulb
  • Bike: DL650 L4
« Reply #9326 on: January 27, 2020, 21:56:46 »
Oil and filter changed...... that's all  :fix:
Offline NeilM
  • Bike: DL650A L4, R1200GS, Triumph TR7 / T140, Bluroc X-Bongo 125
« Reply #9327 on: January 30, 2020, 08:54:26 »
Picked it up from the dealers.
It's in the garage now waiting for Monday so that I can tax it.
Offline Old Biker
  • Bike: DL650A L3
« Reply #9328 on: January 30, 2020, 09:41:26 »
Looking good Neil, you may well spot an identical bike trundling around Somerset!!  :old:
Offline paulja
  • Bike: DL1000XT L8
« Reply #9329 on: January 30, 2020, 16:37:12 »
Had the rear wheel re-spoked under warranty (cheers Haslemere), so dropped the wheel back in with a new tyre to scrub in.
Offline Darren marsh
  • Racer Since 1982
  • Bike: DL650 L0
« Reply #9330 on: January 31, 2020, 14:10:00 »
After a long hard summer from France ,Spain and the uk took the chance today to get the tank of and wash out air filter  :fix: :fix:
With the tank of I noticed the underneath of the tank covered in surface rust what a mess so after a good wipe down and quick going over with some wet&dry 3 coats of white metal spray paint it now looks better than new happy days
Filter washed out and re-oiled all back together and ready for its next hard summer
Living the dream  :auto-dirtbike: :auto-dirtbike:
Safe riding and bring out the sunshine  :sunny:
Offline Dark-Strom
« Reply #9331 on: January 31, 2020, 14:54:06 »
Fitted new givi rails and panniers  :fix:
« Reply #9332 on: January 31, 2020, 16:43:02 »
Just been to fetch her back from 'hospital'.  :)
Valve clearance check
Throttle bodies checked
Wheel bearings front & back, plus cush bearing (all provided by me)
4 x plugs (provided by me)
Front & rear tyres
Fresh coolant
Rear brake caliper serviced & brakes bled
MOT (had to fit number plate bulb)
Can't say it's like riding a new bike yet as the garage is only a mile home & on the wet & greasy roads it didn't feel nice with the new tyres so didn't have a ride out!!  :icon_no:
Just for information 39,499 miles and the valve clearances were all OK.
The front wheel bearing was OK but the back wheel bearing was fooked!
The throttle bodies were out & needed adjusting but he said he would of expected that.
He did mention play in the top shock bearing (up & down) but not a problem yet. May need to get it sorted for next year.
Offline SuzukiSte
« Reply #9333 on: January 31, 2020, 20:14:41 »
Nice one Mick :thumb:
Offline Stonec0ld
  • I was Paul_Nicholson
  • Bike: DL650A L5
« Reply #9334 on: February 01, 2020, 06:05:04 »
Sounds expensive Mick!
« Reply #9335 on: February 01, 2020, 10:49:51 »
Put it this way Paul, it was the price of quite a few Yonderman breakfasts!!  :grin:
However I'm hoping that it's all sorted now and other than a few consumables it'll see the bike out or more than likely me!!  :thumb:
Although I'm still thinking of fitting an aftermarket shock to it soon.
« Reply #9336 on: February 01, 2020, 11:13:25 »
New Shock? that'll be all that luggage I guess :shy:
« Reply #9337 on: February 01, 2020, 12:26:07 »
Brocket, let's just say it's fine if there's only me on it!!!!!  :whistle:
Don't forget......... what's said on the forum stays on the forum!!  :thumb:
« Reply #9338 on: February 01, 2020, 16:49:32 »
Could be all the Yonderman breakfasts you've been riding to. :shrug:
 lol
« Reply #9339 on: February 01, 2020, 17:53:12 »
Maybe not so much riding 'to' as riding 'from'.
