Went to change the rear pads to find that the exhaust clamp was broken - normal problem - Rust.
Pulled the clamp off and spent 30 minutes on the internet trying to buy a replacement. Lots on offer for older bikes. Oh well, off the dealer tomorrow.
Pressing on ... queue 20 minutes of "persuasion" to get the end can detached and then cleaned the wire wool gasket off. Something else to get from the dealer.
Changed the rear pads to find that the outer pad was wearing unevenly. It was stuck at the front (right-hand side as you look at it). Stripped, cleaned and double H pads fitted.
While all that was going on the oil was draining out. Changed the filter and added 3.1L of 10w50 semisynthetic.
On to the front pads and the 1st caliper went without a hitch. Pads definitely needed changing. Cleaned out loads of cr@p and reassembled.
Changing sides and the bike finally won an argument. I can't shift the caliper bolts. They are solid. The first socket was rounding the edges off the bolt head, so I switched to a hex head socket. Even that was slipping.
So, off the dealer tomorrow for the exhaust bits and to order the new caliper bolts, then back to the dealer when they are in and ask them to work their magic in getting the old bolts out.
I love a good fettle in the garage
