Started the winter strip down and maint. session this week - at the rear as usual
Rear wheel out, bearings checked and re-greased.
Rear brake cleaned & inspected (fluid th be changed in the spring).
Swing arm off (thanks Mr Porter for the use of your tools
), all bearings checked and re-lubed.
Popped the rear subframe off whilst I was tooled up and in the mood, and gave it a paint job.
After the rear is back together its onto the front end
Steve T
