Had a few hours tinkering yesterday - Gave the front forks a bit of attention, they've been leaking oil a tad so gave each a 'scrape' between fork and seal with some thin plastic - Pulled some crud out, so hopefully that was the cause... And not going to need a rebuild!
Also finally got around to properly routing the heated grip wiring and fitting my USB charging points to the relay... They made removing the fueltank OTT! 15mins of the day spent figuring out where to route the fuel tank vent pipe, forgot to remove prior to pulling the tank, so pulled out the breather! Figured 'That'll do' after 15mins!
