Today I tackled the broken spotlight clamp
. Went as follows:
- Test spotlight still works following swinging by the wires at 70mph
- New spotlight body drilled to allow angling of the light.
- Spotlight disassembled, water drained out, dried & silicone sealed
- Solder spotlight back in to wiring
- Test spotlights both work via handlebar switch
- Shrink heatshrink
- Test spotlights.... buggers don't work... (neither of them)
- Check fuses (All OK)
- Bugger!!
- Close garage door and worry about it another day
I also noticed the number plate bulb has gone again. I only changed it in July 17 on the day of the last MOT
